VPN Connection to Specific Server Drops
abc1235
Hallo All,
Whenever I connect to a specific server (just this one particular one) via VPN, the connection is dropped but this doesn't happen when I connect directly via LAN. I'd appreciate your input on what could be the possible reason for this. By the way, no firewall is blocking traffic.
Thanks in advance.
Jay
Mark Elsen
 - Is the VPN terminated on the server, if then check the logs on the server related to networking and vpn -connections. If there is an intermediate 'vpn service/server' then the same actions would apply on that device.
 M.
-- Let everything happen to you
       Beauty and terror
      Just keep going
       No feeling is final
Reiner Maria Rilke (1899)
abc1235
Thanks @Mark Elsen for the tip. Is there any specific message I should look out for? (hope this is not a silly question). Thanks.
