%VPN_HW-1-PACKET_ERROR:
ittechk4u1
Level 4
Level 4
Getting these error frequently.....
%VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, MAC Mismatch:srcadr=xxx.xxx.xxx.xxx,dstadr=yyy.yyy.yyy.yyy,size=92,sequence number=0x22F196,SPI=0xF228B568
%VPN_HW-1-PACKET_ERROR: slot: 0 Packet Encryption/Decryption error, Replay Failure:srcadr=xxx.xxx.xxx.xxx,dstadr=yyy.yyy.yyy.yy,size=1368,sequence number=0xA528F,SPI=0x8CCA9598
Can anyone suggest the solution.
Philip D'Ath
With regard to the second error; this usually happens because you are getting packets out of order.  You can only get so many out of order, and then you get a replay error.  I would try expanding the window with:
crypto ipsec security-association replay window-size 256
http://www.cisco.com/c/en/us/td/docs/ios/sec_secure_connectivity/configuration/guide/convert/sec_ipsec_data_plane_15_1_book/sec_ipsec_antireplay.html
The first error could be related to the second.  It could also be a bug.  I would do the above change first, and if the issue happens again try changing to a gold star release of the IOS software.
I will try and let you know.
Even after configuring this command I am getting the same errors as before..
