03-27-2017 05:58 PM - edited 03-05-2019 08:15 AM
ridiculously simple question but I cant find the answer
When you do an sh controller t1 <interface> to show error counts for a T1, how do you determine what time errors in the non-current data interval occurred?
Is data interval 1 15 minutes prior to the current interval - then interval 2 30 minutes, 45 min, etc.
Or the last interval closest to the current interval?
Or is it rolling and neither first or last? In that case how do you determine when, say, interval 10 occurred?
thx
Solved! Go to Solution.
03-28-2017 09:40 AM
Yes. That is the way I have always done it.
To verify, if you have errors, they should move down to the next interval when a new 15 minute period begins.
03-28-2017 07:39 AM
Any ideas anyone? I am trying to identify when interval 30 occurred, knowing that 'current interval' occurred at 20:30
Would it be around 1300 (30 intervals/(4 int per hr) = 7hr 30 min)?
thx
k
03-28-2017 09:40 AM
03-28-2017 03:55 PM
Thanks C,
That seemed logical, but logical isn't always life!
k
03-29-2017 03:59 AM
Totally agree.
Thanks for the rating.
