VPN issue
nathan.carroll
Hello all, I am having a problem getting a vpn to come up. Normally when i get this problem i just turn on all crypto debugging and any piece of logging information points me in the right direction to fixing the VPN. For some reason i am getting no logging information what so ever except the router logs just saying "create signature" every few minutes.
It is a cisco 1812 running iso 12.4. Strange thing is i am not seeing any logging information whatsoever from the peer router or the host router. I have tried different networks (even just a few test ones that would not conflict with out subnet) and have also tried to connecting to different cisco 1812s and a concentrator 3000. no logging info AT ALL. driving me crazy!
any ideas would be awesome. thanks.
muca
Level 3
Level 3
Have you enabled terminal monitor?
router#terminal monitor
Ok i have turned on terminal monitor. Should this give me extra logging?
last few lines of logging have showed
generate publick/private keypair
ISAKMP is OFF
No peer struct to ger peer dessciption
Does this extra information help ?
Nathan
The message that says:
ISAKMP is OFF
is an indicator that IPSec VPN is not working. Perhaps it would help us find the problem if you would post the config.
Rick
Rick
vpn is up, not routing but up
seems for some reason isakmp was actaully off!
