VPN Phone with Cisco 881
andy.rice
I have a new Cisco 881 that I am going to use for my VPN gateway for several NEC phones.  The NEC phones have a VPN client built into them.  I have the 881 configured and have one phone connected and working fine.  Whenever connect a second phone to the gateway the first phone drops and no additional phones will connect.  If I only use one phone, everything works fine.  I have a global group assigned for authentication and have created mulitple users.  What am I going wrong? Any help would be greatly appreciated.
config
! Last configuration change at 20:53:09 UTC Thu Oct 12 2017
version 15.3
hostname PhoneVPNrtr
boot-start-marker
boot-end-marker
aqm-register-fnf
no aaa new-model
ip cef
no ipv6 cef
vpdn enable
vpdn-group 1
! Default L2TP VPDN group
accept-dialin
protocol l2tp
virtual-template 1
no l2tp tunnel authentication
license udi pid C881-K9 sn FGL194327M3
spanning-tree portfast bpduguard
username remotephone1 password 0 P@ssw0rd1!
username remotephone2 password 0 P@ssw0rd1!
username remotephone3 password 0 P@ssw0rd1!
crypto isakmp policy 10
encr aes
hash sha256
authentication pre-share
group 5
crypto isakmp key @sp1r10n! hostname nec_term
crypto isakmp nat keepalive 20
crypto ipsec transform-set nec_enc esp-aes esp-sha256-hmac
mode transport
crypto ipsec profile vpnprof
set transform-set nec_enc
crypto dynamic-map cisco-dynamic 5
set pfs group5
match address cryptoacl
crypto dynamic-map cisco-dynamic5 1
set pfs group5
crypto map cisco-dynamic 5 ipsec-isakmp dynamic cisco-dynamic
interface FastEthernet0
no ip address
interface FastEthernet1
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport trunk allowed vlan 1,2,1002-1005
switchport mode trunk
no ip address
pppoe enable group global
interface FastEthernet4
no ip address
shutdown
duplex auto
speed auto
interface Virtual-Template1
ip unnumbered FastEthernet2
ip nat inside
ip virtual-reassembly in
peer default ip address pool mypool
ppp authentication ms-chap-v2
interface Virtual-Template2
ip nat inside
interface Vlan1
ip address 10.0.0.3 255.255.255.0
interface Vlan2
ip address 172.23.0.253 255.255.255.0
interface Vlan3
no ip address
ip local pool mypool 172.23.0.240 172.23.0.250
ip default-gateway 10.0.0.1
ip forward-protocol nd
no ip http server
no ip http secure-server
ip default-network 10.0.0.1
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip access-list extended cryptoacl
permit ip any any
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password P@ssw0rd1!
login
no modem enable
line aux 0
line vty 0 4
password P@ssw0rd1!
login
transport input ssh
scheduler allocate 20000 1000
end
Unless something has changed, you do:
FL-WEBVPN-10-K9
Feature License SSL VPN for Up to 10 Users (incremental), for 12.4T based IOS releases only
FL-SSLVPN10-K9
Feature License SSL VPN for Up to 10 Users (incremental), for 15.x based IOS releases only
-If I helped you somehow, please, rate it as useful.-
5 Replies 5
 Do you have license?
...No. Geez. So I need a license for each client that will connect? I thought I got more than one out of the box. I am new to cisco please forgive me.
FL-WEBVPN-10-K9
FL-SSLVPN10-K9
Thank you.
Thanks for rating and changing the status to solved. This helps make this forum better.
