Redistribute EIGRP into another EIGRP with different AS
blue phoenix
Hi all,
I need some inputs regarding summarization of subnets in eigrp whether named or classic mode.
I have configured 2 EIGRP AS's. 1 and 2, by behavior they won't see each other unless redistribution is applied. Now if the routes from AS 2 is redistributed to AS 1, the routing table of AS 1 will have D EX tagging on the subnets advertised by AS 2. Pretty straight-forward.
My issue is when I use the summarization command in order to only see 1 line of route instead of 3 lines, it works if it's on the same AS but it doesn't work if it's on different AS's.  The 192.168.x.x is in the same AS1.  172.234.x.x is on AS2.
Can anybody fill in the gaps?
*OSPF is not configured yet here... so don't worry about it.
R1#sh ip route eigrp
Gateway of last resort is not set
      172.234.0.0/24 is subnetted, 3 subnets
D EX     172.234.1.0 [170/1024640] via 10.14.0.4, 01:17:59, Ethernet0/0
                     [170/13556702] via 10.12.0.3, 01:17:59, Serial1/0
                     [170/13556702] via 10.12.0.2, 01:17:59, Serial1/0
D EX     172.234.2.0 [170/1024640] via 10.14.0.4, 01:17:48, Ethernet0/0
                     [170/13556702] via 10.12.0.3, 01:17:48, Serial1/0
                     [170/13556702] via 10.12.0.2, 01:17:48, Serial1/0
D EX     172.234.3.0 [170/1024640] via 10.14.0.4, 01:17:37, Ethernet0/0
                     [170/13556702] via 10.12.0.3, 01:17:37, Serial1/0
                     [170/13556702] via 10.12.0.2, 01:17:37, Serial1/0
D     192.168.0.0/22 [90/1024640] via 10.14.0.4, 00:00:08, Ethernet0/0
                     [90/13556702] via 10.12.0.3, 00:00:08, Serial1/0
                     [90/13556702] via 10.12.0.2, 00:00:08, Serial1/0
R2#sh run | s eigrp
router eigrp INE
 address-family ipv4 unicast autonomous-system 1
  af-interface default
   passive-interface
  exit-af-interface
  af-interface Serial1/0
   summary-address 192.168.0.0 255.255.252.0
   no passive-interface
  exit-af-interface
  af-interface Loopback9
  exit-af-interface
  af-interface Loopback99
  exit-af-interface
  af-interface Loopback999
  exit-af-interface
  topology base
   redistribute eigrp 2
  exit-af-topology
  network 10.12.0.0 0.0.0.255
  network 192.168.0.0 0.0.3.255
 exit-address-family
router eigrp CISCO
 address-family ipv4 unicast autonomous-system 2
   summary-address 172.234.0.0 255.255.0.0
  exit-af-interface
  topology base
  exit-af-topology
  network 172.234.1.0 0.0.0.255
  network 172.234.2.0 0.0.0.255
  network 172.234.3.0 0.0.0.255
 exit-address-family
R3#sh run | s eigrp
router eigrp INE
   passive-interface
  exit-af-interface
  exit-af-interface
  exit-af-interface
  exit-af-interface
  exit-af-interface
  topology base
  exit-af-topology
  network 10.14.0.0 0.0.0.255
 exit-address-family
router eigrp CISCO
  exit-af-interface
  topology base
  exit-af-topology
 exit-address-family
R4#sh run | s eigrp
router eigrp INE
   passive-interface
  exit-af-interface
  exit-af-interface
  af-interface Ethernet0/0
  exit-af-interface
  exit-af-interface
  exit-af-interface
  exit-af-interface
  topology base
  exit-af-topology
 exit-address-family
router eigrp CISCO
  exit-af-interface
  topology base
  exit-af-topology
 exit-address-family
GRANT3779
Just had a brief look over and I believe your summary address should be under AS1 process on your routers - Not under AS 2.
exit-af-interface
GRANT3779
exit-af-interface
