vrf configuration on ISR 4221 Router
Muthukumar P
HI team,
            We required  VRF configuration document/example for ISR 4221 Router, accordingly whether required any additional license required for VRF configuration on ISR 4221 or specific firmware version required for VRF configuration on ISR 4221 Router.Please guide and suggest on this.
Muthukumar
are you looking for VRF or VRF-Lite ? VRF requires AX (Application Experience), VRF-Lite I think is included in the default IP Base license...
https://www.cisco.com/c/en/us/products/collateral/routers/4000-series-integrated-services-routers-isr/data_sheet-c78-732542.html
Giuseppe Larosa
Hello Muthukumar,
verify the licenses installed with
show license
To see if vrf are supported perform the following test:
config t
vrf definition test
rd 100:100
if the vrf definition test command is accepted you can configure VRFs
Hope to help
Giuseppe
