09-19-2022
08:10 AM
- last edited on
09-19-2022
11:40 AM
by
Translator
I am getting an error while assigning
IP vrf forwarding F-1
command under the interface
R38(config-if)#ip vrf forwarding ?
F-1 VRF Name
WORD VRF name
f-1 VRF Name
R38(config-if)#ip vrf forwarding F-1
% Use 'vrf forwarding' command for VRF F-1
R38(config-if)#
Solved! Go to Solution.
09-19-2022
08:14 AM
- last edited on
09-19-2022
11:43 AM
by
Translator
Hi @R Manjunatha ,
vrf forwarding F-1
is the new format for this command.
is the old format. You should be using the new format.
09-19-2022
08:14 AM
- last edited on
09-19-2022
11:43 AM
by
Translator
Hi @R Manjunatha ,
vrf forwarding F-1
09-19-2022 08:27 AM
Yes, that is correct ...Thanks
