I have a small doubt that i would like to clarify. please look at my topology below
PC1-------Router---------PC2
Routers interface towards PC1 is in VRF named as "one" and interface towards PC2 is in vrf named as "two". i have "NAT inside on router's interface towards PC1 and "NAT oustside" on interface towards PC2. i have one one way route vrf route leaking and there is a static NAT in vrd "one" for PC1 address. please check the configuration below from router:
R2#sh run | se bgp
router bgp 65000
no synchronization
bgp router-id 10.10.10.2
bgp log-neighbor-changes
no auto-summary
address-family ipv4 vrf one
no synchronization
redistribute connected
exit-address-family
address-family ipv4 vrf two
no synchronization
exit-address-family
R2#sh run | in nat
ip nat inside source static 10.10.10.1 40.40.40.1 vrf one
R2#sh run vrf one
vrf definition one
rd 1:1
route-target export 1:1
route-target import 2:2
address-family ipv4
exit-address-family
interface FastEthernet0/0
vrf forwarding one
ip address 10.10.10.2 255.255.255.0
ip nat inside
duplex half
router bgp 65000
no synchronization
exit-address-family
end
R2#sh run vrf two
Building configuration...
Current configuration : 375 bytes
vrf definition two
rd 2:2
route-target export 2:2
address-family ipv4
exit-address-family
interface FastEthernet1/0
vrf forwarding two
ip address 20.20.20.2 255.255.255.0
ip nat outside
speed auto
duplex auto
router bgp 65000
no synchronization
exit-address-family
end
Routing table from router:
R2#sh ip route vrf one
Gateway of last resort is not set
10.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 10.10.10.0/24 is directly connected, FastEthernet0/0
L 10.10.10.2/32 is directly connected, FastEthernet0/0
20.0.0.0/24 is subnetted, 1 subnets
B 20.20.20.0 is directly connected, 00:55:53, FastEthernet1/0
R2#sh ip route vrf two
20.0.0.0/8 is variably subnetted, 2 subnets, 2 masks
C 20.20.20.0/24 is directly connected, FastEthernet1/0
L 20.20.20.2/32 is directly connected, FastEthernet1/0
When i ping from PC1 to PC2 it works, although the VRF leaking is only one way. can you please explain how it is working? i
