12-18-2012 04:15 AM - last edited on 03-25-2019 03:37 PM by ciscomoderator
Hello all.
Another issue with BGP administrative distance
I have two VRFs; a few connected VLANs interfaces and a BGP process to leak routes between these VRFs. Everything works fine.
Now I want to change the administrative distance of BGP in order to get a leaked route only of the route is not natively learnt through an IGP; the "leaking" is only used as a backup path.
Hardware : Cat6500 / VSS / IOS 12.2(33)SXI6
ip vrf Green
rd 65000:2
route-target export 65000:2
route-target import 65000:2
route-target import 65000:3
ip vrf Red
rd 65000:3
route-target export 65000:3
router bgp 65000
no synchronization
bgp log-neighbor-changes
distance bgp 200 200 200
distance mbgp 199 199 199
no auto-summary
address-family ipv4 vrf Red
redistribute connected metric 500
no synchronization
exit-address-family
address-family ipv4 vrf Green
no synchronization
exit-address-family
CORE-01#show ip route vrf Red
Routing Table: Red
Codes: C - connected, S - static, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2
i - IS-IS, su - IS-IS summary, L1 - IS-IS level-1, L2 - IS-IS level-2
ia - IS-IS inter area, * - candidate default, U - per-user static route
o - ODR, P - periodic downloaded static route
Gateway of last resort is not set
10.0.0.0/24 is subnetted, 6 subnets
B 10.0.10.0 is directly connected, 00:04:31, Vlan10
C 10.0.8.0 is directly connected, Vlan8
C 10.0.6.0 is directly connected, Vlan6
B 10.0.11.0 is directly connected, 00:03:12, Vlan11
B 10.0.9.0 is directly connected, 00:04:31, Vlan9
C 10.0.7.0 is directly connected, Vlan7
CORE-01#show ip route vrf Red 10.0.10.0
Routing entry for 10.0.10.0/24
Known via "bgp 65000", distance 20, metric 500 (connected, via interface), type external
Routing Descriptor Blocks:
* directly connected, via Vlan10
Route metric is 500, traffic share count is 1
AS Hops 0
MPLS label: none
CORE-01#show ip bgp vpnv4 all
BGP table version is 19, local router ID is 172.16.201.2
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale
Origin codes: i - IGP, e - EGP, ? - incomplete
Network Next Hop Metric LocPrf Weight Path
Route Distinguisher: 65000:2 (default for vrf Green)
*> 10.0.6.0/24 0.0.0.0 500 32768 ?
*> 10.0.7.0/24 0.0.0.0 500 32768 ?
*> 10.0.8.0/24 0.0.0.0 500 32768 ?
*> 10.0.9.0/24 0.0.0.0 500 32768 ?
*> 10.0.10.0/24 0.0.0.0 500 32768 ?
*> 10.0.11.0/24 0.0.0.0 500 32768 ?
Route Distinguisher: 65000:3 (default for vrf Red)
12-19-2012 12:48 AM
Nobody ?
12-19-2012 01:31 AM
Hello Surya,
I haven't done this before, but my immediate thought is to simply use the distance command in the appopriate BGP's address-family ipv4 section to modify the leaked route's AD to be higher than the IGP's AD. You will need to configure an ACL that describes the prefix whose AD you need to modify (like a classic distance command).
Best regards,
Peter
12-19-2012 02:19 AM
ok thank you.
I'll try
12-19-2012 02:22 AM
Hi Surya,
Sure. Do you need any assistance with configuring that?
Best regards,
Peter
02-26-2018 02:24 PM
I would like some assistance as I'm having the same issue. Your method does work, however in my situation it won't work since I need to ensure that specifically leaked routes have the administrative distance changed, and not BGP in general, since I have BGP Peers that need to have their administrative distance remain default.
