VRF Routing problem
K3ra
Hi All,
I'm playing with following scenario and I faced some problem:
R3 - R4 iBGP
R9 to R3 and R4 eBGP
R9#sh ip bgp summary
BGP router identifier 9.9.9.9, local AS number 9
BGP table version is 1, main routing table version 1
Neighbor        V           AS MsgRcvd MsgSent   TblVer  InQ OutQ Up/Down  State/PfxRcd
3.3.3.3         4            1      31      28        1    0    0 00:18:34        0
4.4.4.4         4            1      32      28        1    0    0 00:19:06        0
Ping inside VRF A from left to right is working, the same for VRF B.
R6#sh ip route
Gateway of last resort is not set
6.0.0.0/32 is subnetted, 1 subnets
C        6.6.6.6 is directly connected, Loopback0
      7.0.0.0/32 is subnetted, 1 subnets
O IA     7.7.7.7 [110/21] via 172.16.1.1, 00:11:10, Ethernet0/3
      172.16.0.0/16 is variably subnetted, 3 subnets, 2 masks
C        172.16.1.0/24 is directly connected, Ethernet0/3
L        172.16.1.2/32 is directly connected, Ethernet0/3
O IA     172.16.2.0/24 [110/11] via 172.16.1.1, 00:11:10, Ethernet0/3
R6#ping 7.7.7.7
Sending 5, 100-byte ICMP Echos to 7.7.7.7, timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip min/avg/max = 4/5/6 ms
R6#traceroute 7.7.7.7 numeric
VRF info: (vrf in name/id, vrf out name/id)
  1 172.16.1.1 5 msec 4 msec 5 msec
  2 10.10.13.1 [MPLS: Labels 16/25 Exp 0] 5 msec 5 msec 5 msec
  3 172.16.2.1 [MPLS: Label 25 Exp 0] 5 msec 6 msec 5 msec
  4 172.16.2.2 5 msec *  1 msec
I added 3rd VRF AB on R9. I would like to ping from R9 - lo99 (vrf AB ) ping R7 - lo0 but it fail. Route is injected:
R9#ping vrf AB 7.7.7.7
Success rate is 0 percent (0/5)
R9#sh ip route vrf AB Gateway of last resort is not set 7.0.0.0/32 is subnetted, 1 subnets B 7.7.7.7 [20/10] via 4.4.4.4, 00:02:52 44.0.0.0/32 is subnetted, 1 subnets B 44.44.44.44 [20/0] via 4.4.4.4, 00:26:40 99.0.0.0/32 is subnetted, 1 subnets C 99.99.99.99 is directly connected, Loopback99 172.16.0.0/24 is subnetted, 1 subnets B 172.16.2.0 [20/0] via 4.4.4.4, 00:26:40
Route back from R7 to R9 lo99
R7#sh ip route
O IA     6.6.6.6 [110/21] via 172.16.2.1, 00:27:22, Ethernet0/3
C        7.7.7.7 is directly connected, Loopback0
O E2     44.44.44.44 [110/1] via 172.16.2.1, 00:27:29, Ethernet0/3
O E2     99.99.99.99 [110/1] via 172.16.2.1, 00:27:22, Ethernet0/3
O IA     172.16.1.0/24 [110/11] via 172.16.2.1, 00:27:22, Ethernet0/3
C        172.16.2.0/24 is directly connected, Ethernet0/3
L        172.16.2.2/32 is directly connected, Ethernet0/3
I attach the configuration of R4
R4:
ip vrf A
 rd 100:2
 route-target export 100:2
 route-target import 100:1
ip vrf AB
 rd 300:1
 route-target export 300:1
 route-target import 300:1
 route-target import 200:2
ip vrf B
 rd 200:2
 route-target export 200:2
 route-target import 200:1
interface Loopback0
 ip address 4.4.4.4 255.255.255.255
 ip ospf 1 area 0
interface Loopback44
 ip vrf forwarding AB
 ip address 44.44.44.44 255.255.255.255
interface Ethernet0/0
 ip address 10.10.14.2 255.255.255.252
 ip ospf 1 area 0
interface Ethernet0/1
 ip address 10.10.24.2 255.255.255.252
 ip ospf 1 area 0
interface Ethernet0/2
 ip vrf forwarding A
 ip address 192.168.2.1 255.255.255.0
 ip ospf 3 area 3
interface Ethernet0/3
 ip vrf forwarding B
 ip address 172.16.2.1 255.255.255.0
 ip ospf 3467 area 3467
router ospf 3 vrf A
 redistribute bgp 1 subnets
router ospf 3467 vrf B
router ospf 1
 mpls ldp autoconfig
 router-id 4.4.4.4
router bgp 1
 bgp router-id 4.4.4.4
 bgp log-neighbor-changes
 neighbor 3.3.3.3 remote-as 1
 neighbor 3.3.3.3 update-source Loopback0
 neighbor 9.9.9.9 remote-as 9
 neighbor 9.9.9.9 ebgp-multihop 5
 neighbor 9.9.9.9 update-source Loopback0
 neighbor 9.9.9.9 next-hop-self
 address-family vpnv4
  neighbor 3.3.3.3 activate
  neighbor 3.3.3.3 send-community extended
  neighbor 9.9.9.9 activate
  neighbor 9.9.9.9 send-community extended
  neighbor 9.9.9.9 route-map R7 out
 exit-address-family
 address-family ipv4 vrf A
  redistribute ospf 3
 exit-address-family
 address-family ipv4 vrf AB
  redistribute connected
 exit-address-family
 address-family ipv4 vrf B
  redistribute ospf 3467
 exit-address-family
route-map R7 permit 10
 match ip address 1
 set metric 10
route-map R7 permit 20
access-list 1 permit 7.7.7.7
R9:
R9:
ip vrf AB
 rd 300:1
interface Loopback0
 ip address 9.9.9.9 255.255.255.255
interface Loopback99
 ip address 99.99.99.99 255.255.255.255
 no ip address
 shutdown
 no ip address
 shutdown
 no ip address
 shutdown
 ip address 192.168.9.2 255.255.255.0
router bgp 9
 bgp router-id 9.9.9.9
 neighbor 3.3.3.3 ebgp-multihop 5
 neighbor 4.4.4.4 remote-as 1
 neighbor 4.4.4.4 ebgp-multihop 5
 neighbor 4.4.4.4 update-source Loopback0
 neighbor 4.4.4.4 next-hop-self
  neighbor 4.4.4.4 activate
  neighbor 4.4.4.4 send-community extended
 exit-address-family
 exit-address-family
ip route 0.0.0.0 0.0.0.0 Ethernet0/3
R9#sh ip bgp all
For address family: IPv4 Unicast
     Network          Next Hop            Metric LocPrf Weight Path
Route Distinguisher: 200:2
 *   7.7.7.7/32       3.3.3.3                100             0 1 ?
 *>                   4.4.4.4                 10             0 1 ?
 *   172.16.2.0/24    3.3.3.3                                0 1 ?
 *>                   4.4.4.4                  0             0 1 ?
Route Distinguisher: 300:1 (default for vrf AB)
 *>  7.7.7.7/32       4.4.4.4                 10             0 1 ?
 *>  44.44.44.44/32   4.4.4.4                  0             0 1 ?
 *>  99.99.99.99/32   0.0.0.0                  0         32768 ?
 *>  172.16.2.0/24    4.4.4.4                  0             0 1 ?
Can somebody help me with this ? I'm pretty sure I miss something. If any other outputs needed please let me know.
Giuseppe Larosa
Hello @K3ra ,
try to put R9 in BGP AS number 1
you are mixing an extranet with inter AS VPN it may be too much together.
First try the extranet concepts using a single ISP AS number 1 on all PE nodes.
Later you can try to test inter AS VPN options.
Hope to help
Giuseppe
Hi Giuseppe,
thank you for reply. I'll try it out today and give feedback later.
KR
k3ra
