VRF to GRT with BGP
rpalmeida
Hi.
Is there any way to do route leaking VRF<->GRT and GRT<->VRF with BGP or MBP?
I usually do with a cable in 2 ports in same switch or the traditional way, with Tunnels and IGP ( like ISIS, or OSPF or EIGRP ).
In attachment i send an example of my traditional config with Tunnels, but the goal is to do with BGP or MBGP.
Many thanks in advanced.
5 Replies 5
Configure VRF Leaks on IOS XE - Cisco
check scenario 3 this what you looking for
MHM
rpalmeida
Hi MHM,
I dont have the command "export ipv4 unicast map" in GNS3, with the image of 7200, to test the config before i implement it.
I have only the "import ipv4 unicast map", under VRF.
Best Regards MHM.
Yes I know' 7200 in gns3 dont have import and export command between global and vrf.
MHM
rpalmeida
 MHM.
I just tried with Cisco Catalyst 3560G-48 and when i do "vrf definition" i receive a information that says:
Switch(config)#vrf definition A
% Command accepted but obsolete, unreleased or unsupported; see documentation.
I will try in Cisco Catalyst 6506.
Tomorrow will say something.
Thanks for your support.
p.s. In attachment sending the IOS of 3560G and the config that worked with tunnels and filtering.
Best regards MHM.
rpalmeida
Hi MHM,
I tried with Catalyst 6506 and 6506 with IOS v.12 and that command ( export ipv4 ), isnt avaible.
Well i will try to go around this.
