VRF to VRF: static routing with SVI
iores
Level 3
Level 3
I am doing some labs, and I have connected three switches:
The link between SW1 and SW2 is in VRF A, and link between SW2 and SW3 is in VRF B. I want to be able to ping SW3 from SW1 and vice-versa but somehow it doesn't work.
What is the problem?
Here are my configs.
SW1:
interface GigabitEthernet0/0
 switchport mode trunk
 negotiation auto
interface Vlan10
 ip vrf forwarding A
 ip address 10.10.10.10 255.255.255.0
ip route vrf A 0.0.0.0 0.0.0.0 10.10.10.11
SW2:
 negotiation auto
interface GigabitEthernet0/1
 negotiation auto
interface Vlan10
 ip vrf forwarding A
 ip address 10.10.10.11 255.255.255.0
interface Vlan20
 ip vrf forwarding B
 ip address 20.20.20.21 255.255.255.0
ip route 10.10.10.11 255.255.255.255 Vlan10
ip route 20.20.20.21 255.255.255.255 Vlan20
ip route vrf A 20.20.20.0 255.255.255.0 20.20.20.21 global
ip route vrf B 10.10.10.0 255.255.255.0 10.10.10.11 global
SW3:
 negotiation auto
interface Vlan20
 ip vrf forwarding B
 ip address 20.20.20.20 255.255.255.0
ip route vrf B 0.0.0.0 0.0.0.0 20.20.20.21
2 Accepted Solutions
ip route 10.10.10.10 255.255.255.255 Vlan10
ip route 20.20.20.20 255.255.255.255 Vlan20
ip route vrf A 20.20.20.0 255.255.255.0 20.20.20.20 global
ip route vrf B 10.10.10.0 255.255.255.0 10.10.10.10 global
I make check and double check, I was thing that SW not support leaking with static route,
but I stop
what is the next-hop we use,
I check and find issue
we use next-hop which is SVI in same SW, that wrong
correct as above and check again
thanks
Joseph W. Doherty
Routing leaking, eh?  Long, long time since I've touched, and then, very infrequently.
So, possibly (? - i.e. crossed fingers):
13 Replies 13
I followed the similar example for VRF-to-VRF with static routing from here http://routeleak.com/route-leaking-global-vrf-routing-table/ but I want to use SVI instead routers.
check below comment
But 10.10.10.0 and 20.20.20.0 are in VLAN10 and VLAN20, respectively. What will I achieve with this?
what we try is add
 static route in show ip route vrf a/b for prefix of VLAN10/20
ip route vrf VRF-B 10.10.10.0 255.255.255.0 VLAN10
ip route vrf VRF-A 20.20.20.0 255.255.255.0 VLAN20
I cannot do that because I need to specify next-hop IP address not vlan interface. What is wrong with my configs?
in SW2
ip route vrf VRF-B 10.10.10.0 255.255.255.0 10.10.10.11  global
ip route vrf VRF-A 20.20.20.0 255.255.255.0 20.20.20.21 global
interface Vlan10
 ip vrf forwarding A <<- remove this
interface Vlan20
 ip vrf forwarding B <<- remove this
I am trying to do VRF-to-VRF leak.
SW1(VRF-A)-(global)SW2(global)-(VRF-B)SW3
so we do static route in SW2 for leaking from VRF to VRF.
am I right ?
SW1(VRF-A)-(VRF-A)SW2(VRF-B)-(VRF-B)SW3.
I want to do a route leak on SW2 from VRF to VRF.
I found issue here
but I stop
thanks
Joseph W. Doherty
