VRF transitive?
Kevin-H
Does anyone know if VRF is transitive?
vrf Internet
import/export Guests
import/export Creditcards
vrf Guests
import/export Internet
vrf Creditcards
Would Guests & Creditcards be able to talk to each other, through the Internet vrf?
If so, is ACL or firewall the only way to stop them from talking to each other?
TIA
Julio E. Moisa
I have not applied that before but it could works, other way to allow the communication between VRF is with the following configuration:
vrf Guests
import/export route-target (Guest)
 import route-target (Creditcards)
vrf Creditcards
import/export route-target (Creditcards)
 import route-target (Guest)
Hope it is useful
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thank you for the quick reply, but we actually don't want Guests & Creditcards to talk to each other for security reasons.
If Guests & Creditcards don't import/export each other's RT, they should not be able to talk to each other, correct? (which is what we want)
That is correct, actually if they don't import the each other VRFs.
Now if you want to allow Internet access for them separately, you can keep the Internet default route on the global table.
