VSL link issue
Vignesh M
Community Member
If I configure 2 VSL links between VSS, what would be its behaviour?
Whether the redundant VSL link will behave like a STP redundant path and it will be blocked or the both will be active?
Thanks and Regards,
Vicky
Mark Malone
You can have up to 8 links in one VSL setup so theres no real need to create two instances as there should be plenty of redundancy in 8 links when set as an etherchannel
