VTP version is not the same on server and client
okin283
I have a VTP server on Cisco 3750 with this configuration:
#sh vtp status
VTP version : 2
Configuration Revision : 31
VTP V2 Mode : Disabled
I connect a 2960 on this VTp server and i get:
#sh vtp status
VTP Version                     : running VTP1 (VTP2 capable)
Maximum VLANs supported locally : 255
Number of existing VLANs        : 20
VTP Operating Mode              : Client
VTP Domain Name                 : DOMAINE
VTP Pruning Mode                : Enabled
VTP Traps Generation            : Disabled
On the othe client VTP client I have a VTP Version = 2.
But on my new 2960, i receive all of Vlan...
Is there any probleme?
Thanks for your help.
Nicolas
Lei Tian
Hi Nicolas,
#sh vtp status
You need to check the highlight field to find what VTP version is running. The top VTP version just tell you this switch is able to do VTP v2 or not.
HTH,
Lei Tian
Lei Tian
Hi Nicolas,
#sh vtp status
HTH,
Lei Tian
Okay on server and client i have "VTP V2 Mode : Disable"
Thanks you!!
