04-06-2016 09:54 PM - edited 03-05-2019 03:44 AM
VWIC-2MFT-E1 not seen in configuration. After inserting module in Cisco3825 I not see it in show run, but I can see it in show inv and show diag
Ustk_VG1#sh inv
NAME: "3825 chassis", DESCR: "3825 chassis"
PID: CISCO3825 , VID: V02 , SN: FCZ101870EM
NAME: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1 on Slot 0 SubSlot 0", DESCR: "VWIC2-2MFT-T1/E1 - 2-Port RJ-48 Multiflex Trunk - T1/E1"
PID: VWIC2-2MFT-T1/E1 , VID: V01 , SN: FOC11022UC3
NAME: "3rd generation four port FXS DID voice interface daughtercard on Slot 0 SubSlot 2", DESCR: "3rd generation four port FXS DID voice interface daughtercard"
PID: VIC3-4FXS/DID , VID: V03 , SN: FOC1544177F
NAME: "Two port E1 voice interface daughtercard on Slot 0 SubSlot 3", DESCR: "Two port E1 voice interface daughtercard"
PID: VWIC-2MFT-E1= , VID: 1.0, SN: 33233062
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 4", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC10140W6Y
NAME: "PVDMII DSP SIMM with four DSPs on Slot 0 SubSlot 5", DESCR: "PVDMII DSP SIMM with four DSPs"
PID: PVDM2-64 , VID: V01 , SN: FOC10123VE1
Ustk_VG1#show diag
Slot 0:
C3825 Mother board 1GE(TX,SFP),1GE(TX), integrated VPN and 4W Port adapter, 13 ports
Port adapter is analyzed
Port adapter insertion time 02:39:32 ago
EEPROM contents at hardware discovery:
PCB Serial Number : FOC101022HB
Hardware Revision : 1.1
Top Assy. Part Number : 800-23087-02
Board Revision : A0
Deviation Number : 0
Fab Version : 07
RMA Test History : 00
RMA Number : 0-0-0-0
RMA History : 00
Processor type : 61
Hardware date code : 20060308
Chassis Serial Number : FCZ101870EM
Chassis MAC Address : 0017.0e81.2890
MAC Address block size : 32
CLEI Code : IPMEY10BRA
Product (FRU) Number : CISCO3825
Part Number : 73-4021-07
Version Identifier : V02
EEPROM format version 4
EEPROM contents (hex):
0x00: 04 FF C1 8B 46 4F 43 31 30 31 30 32 32 48 42 40
0x10: 04 2A 41 01 01 C0 46 03 20 00 5A 2F 02 42 41 30
0x20: 88 00 00 00 00 02 07 03 00 81 00 00 00 00 04 00
0x30: 09 61 83 01 32 18 94 C2 8B 46 43 5A 31 30 31 38
0x40: 37 30 45 4D C3 06 00 17 0E 81 28 90 43 00 20 C6
0x50: 8A 49 50 4D 45 59 31 30 42 52 41 CB 89 43 49 53
0x60: 43 4F 33 38 32 35 82 49 0F B5 07 89 56 30 32 20
0x70: D9 02 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 0:
64-channel (G.711) Voice/Fax PVDMII DSP SIMM PVDM daughter card
Hardware Revision : 4.0
Part Number : 73-8541-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10140W6Y
RMA History : 00
Processor type : 00
Product (FRU) Number : PVDM2-64
Version Identifier : V01
0x00: 04 FF 40 03 EC 41 04 00 82 49 21 5D 05 42 41 30
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 34
0x20: 30 57 36 59 03 00 81 00 00 00 00 04 00 09 00 CB
0x30: 88 50 56 44 4D 32 2D 36 34 89 56 30 31 20 D9 02
0x40: 40 C1 FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x50: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x60: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
0x70: FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF FF
PVDM Slot 1:
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC10123VE1
RMA History : 00
Processor type : 00
0x10: 88 00 00 00 00 02 04 C1 8B 46 4F 43 31 30 31 32
0x20: 33 56 45 31 03 00 81 00 00 00 00 04 00 09 00 CB
WIC Slot 0:
Hardware Revision : 0.0
Top Assy. Part Number : 800-22629-05
Board Revision : A0
Fab Version : 04
PCB Serial Number : FOC11022UC3
RMA History : 00
Product (FRU) Number : VWIC2-2MFT-T1/E1
0x00: 04 FF 40 03 FC 41 00 00 C0 46 03 20 00 58 65 05
0x10: 42 41 30 88 00 00 00 00 02 04 C1 8B 46 4F 43 31
0x20: 31 30 32 32 55 43 33 03 00 81 00 00 00 00 04 00
0x30: CB 90 56 57 49 43 32 2D 32 4D 46 54 2D 54 31 2F
0x40: 45 31 89 56 30 31 20 D9 02 40 C1 FF FF FF FF FF
WIC Slot 2:
3rd generation - FXS DID Voice daughter card (4 port)
Hardware Revision : 1.0
Top Assy. Part Number : 800-33583-01
Board Revision : D0
Fab Version : 07
PCB Serial Number : FOC1544177F
RMA History : 00
Product (FRU) Number : VIC3-4FXS/DID
Version Identifier : V03
CLEI Code : IPUIA6JRAC
Longitudinal Calibration : 01 10 10 8C 6C 10 10 85
66 10 10 88 83 10 10 A8
68
0x00: 04 FF 40 05 1B 41 01 00 C0 46 03 20 00 83 2F 01
0x10: 42 44 30 88 00 00 00 00 02 07 C1 8B 46 4F 43 31
0x20: 35 34 34 31 37 37 46 03 00 81 00 00 00 00 04 00
0x30: CB 8D 56 49 43 33 2D 34 46 58 53 2F 44 49 44 89
0x40: 56 30 33 20 D9 02 40 C1 C6 8A 49 50 55 49 41 36
0x50: 4A 52 41 43 D3 11 01 10 10 8C 6C 10 10 85 66 10
0x60: 10 88 83 10 10 A8 68 FF FF FF FF FF FF FF FF FF
WIC Slot 3:
E1 (2 port) Multi-Flex Trunk WAN daughter card
Hardware revision 1.0 Board revision B0
Serial number 33233062 Part number 800-04479-03
FRU Part Number VWIC-2MFT-E1=
Test history 0x0 RMA number 00-00-00
Connector type PCI
EEPROM format version 1
0x20: 01 23 01 00 01 FB 18 A6 50 11 7F 03 00 00 00 00
0x30: 58 00 00 00 02 09 13 00 FF FF FF FF FF FF FF FF
Ustk_VG1#dir
Directory of flash:/
1 -rw- 50883348 Sep 24 2012 18:13:56 +06:00 c3825-ipvoicek9-mz.124-24.T7.bin
Ustk_VG1#sh run
Building configuration...
Current configuration : 5931 bytes
version 12.4
service timestamps debug datetime localtime show-timezone
service timestamps log datetime localtime show-timezone
service password-encryption
hostname Ustk_VG1
boot-start-marker
boot-end-marker
card type e1 0 0
logging message-counter syslog
logging buffered 32000
enable secret XXXX
aaa new-model
aaa authentication login admins group tacacs+ line
aaa authentication enable default group tacacs+ enable
aaa session-id common
clock timezone Almaty 6
network-clock-participate wic 0
network-clock-select 1 E1 0/0/0
dot11 syslog
ip source-route
ip cef
no ip dhcp use vrf connected
no ip dhcp conflict logging
ip dhcp excluded-address 10.46.3.1 10.46.3.10
ip dhcp pool IP_Phones
network 10.46.3.0 255.255.255.0
default-router 10.46.3.1
dns-server 10.2.1.4
domain-name kkb.kz
option 150 ip 10.3.11.112
lease 5
no ip domain lookup
ip domain name kkb.kz
ip host CCM 1.1.1.1
ip host CCMS1 1.1.1.1
ip host CCMS2 1.1.1.1
ip host CCMS3 1.1.1.1
ip name-server 1.1.1.1
no ipv6 cef
isdn switch-type primary-net5
voice-card 0
dspfarm
dsp services dspfarm
voice service voip
fax protocol t38 ls-redundancy 0 hs-redundancy 0 fallback cisco
modem passthrough nse codec g711ulaw
voice hunt-group 1 peer
list 71101,71102,71103,71104
timeout 60
pilot 71100
application
service disa flash:session1.tcl
global
service alternate disa
archive
log config
hidekeys
controller E1 0/0/0
framing NO-CRC4
pri-group timeslots 1-31 service mgcp
description "To ODT-1"
controller E1 0/0/1
framing NO-CRC4
description "To ODT-2"
ip ssh version 2
interface Port-channel1
description Trunk_to_C3750G
no ip address
hold-queue 150 in
