I am planning to install a 3825 router that will be a data WAN router and a voice gateway. It will have a data T1 and a voice PRI. Can the same VWIC2-2MFT-T1/E1 card serve both circuits? Or once I configure 'voice-card 0' will that card be only usable for voice?
I've not yet tried using both voice and data on the same card, but I think it should work by specifying "pri-group" for the firstcontroller T1 and "channel-group" for the second controller.
Perhaps others can shed some lights on this..
hth,
hieu
Learn, share, save
