WAE models
net-tec
Is the WAE 512 recommended for the central manager ?
a.alekseev
Level 7
Level 7
any WAE server can be used for central manager.
But because it will be used only for management you can use lowest one.
Use two WAE512 as central manager for redundancy.
So it is possible to run central manager on WAE-512 while the accelerators on WAE-674?
