WAN Compression Possible?
ahmad82pkn
Level 3
Level 3
Hi , i have 7204VXR at my head office, that is running an OC3 connection , which is now a day shitting around 130Mbps traffic and with more branches opening i am expecting it to hit 145 Meg soon.
is there a way i can compress the traffic to around 100Meg let say?, instead of increasing my bandwidth to 200Meg which is costly.
is there any solution from Cisco?? or Any third party hardware someone would liek to recommend?
vmiller
Level 7
Level 7
Look at Cisco Wide area application services module.
Make sure you understand the nature of your data To see if WAAS is even a fit for your environment.
I'd think about getting off that 7200 also.
Joseph W. Doherty
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
At OC3 bandwidths, Cisco and 3rd party solutions really address WAN acceleration, of which compression is often a part.  However, for just using those for compression, you might find they are not inexpensive.
Another approach, is "management" of your bandwidth with QoS.  If your application bandwidth needs differ, you may find you have "ample" bandwidth, even with links running at 100%.  Year ago, I had a set of E3s that ran at 100% all during business hours, and had everything on them from VoIP to server backups.  Users didn't complain because I had sufficient bandwidth to satisfy application requirements.
