WAN interface is not getting DHCP address if crypto ipsec profile enable
rec stalmaski
I run into situation wherin branch router was configured to be connected in WAN-dhcp based ISP. This branch router is using IPSEC protecting to traffic towards HQ.
This is my first encouter and my observation was, if i crypto profile is configured to WAN interface, it will not  obtain IP address from DHCP but after I remove crypto, it will obtain DHCP ip address and then i need to put back the crypto profile. My concern is what if in future router is rebooted crypto profile is present in interface, then it wouldn't get ip address unless profile was remove then after obtaining IP again, I need to manually put the profile.anyone of you guys run into situation like this before?
WAN <interface>
ip-address dhcp
tunnel mode ipsec ipv4
tunnel source LoopbackX
tunnel protection ipsec profile Branch-IPSEC
nagasheshu2010
We have done the same configuration in CISCO891-K9 router with IOS version C890 Software (C890-UNIVERSALK9-M), Version 15.2(3)T1, RELEASE SOFTWARE (fc1)
We have had no issues, we have already had Crypto  config under the interface and then we added IP address dhcp command. Interface picked up IP address and crypto came up after that.
Not sure if it is IOS dependent, what device and IOS you are on?
Sheshu.
Hi Nagesh,
I am using CISCO1941/K9  and both tried Version 15.2(4) and SPA.153-3.M but getting same. I will test in other hardware model after i have  available.
I attached test which i am using. my assumption is that once interface has crypto profile, it should be encrypted and will not received the broadcast response from DHCP based device. However as per your response, it was tested good from your end. Maybe i am missing something?
I believe that the issue here is that when you use tunnel protection ipsec profile that it treats all traffic going through the interface as traffic to encrypt, including your dhcp traffic. I believe that this feature is intended to be used on tunnel interfaces and not on the physical interface.
The origonal post indicates that the intent is that branch will encrypt traffic to HQ. But with this config on the physical interface it will encrypt all traffic. The solution would be to configure a tunnel to carry traffic to HQ and put the ipsec profile on the tunnel.
Rick
Rick
