WAN : POS interface information
lrichet31
I have cisco routers on a WAN link (SDH). When i run the command "show interface POS X/X/X", what is the rate which appears ?
Example :  show interfaces pos 2/0/0
POS2/0/0 is up, line protocol is up
  Hardware is cyBus Packet over Sonet
  Description: PRI-T1 net to zippy (4K) to Pac-Bell
  Internet address is 1.1.1.1/27
  MTU 4470 bytes, BW 1000 Kbit, DLY 40000 usec, rely 255/255, load 1/255
  Encapsulation HDLC, loopback not set, keepalive set (3 sec)
  Last input 00:00:00, output 00:00:00, output hang never
  Last clearing of "show interface" counters 00:23:09
  Queueing strategy: fifo
  Output queue 0/40, 0 drops; input queue 0/75, 0 drops
  5 minute input rate 0 bits/sec, 1 packets/sec
  5 minute output rate 1000 bits/sec, 1 packets/sec
     1046 packets input, 54437 bytes, 0 no buffer
     Received 485 broadcasts, 0 runts, 0 giants, 0 parity
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     4013 packets output, 1357412 bytes, 0 underruns
     0 output errors, 0 applique, 0 interface resets
     0 carrier transitions
The 2 lines input & output rate, Cisco says "Average number of bits and packets received or transmitted per second in the last 5 minutes."
But i want to know if it's a layer 3 rate or a layer 2 rate ? I know that's the SDH packets are not counted but i want to know if HDLC&PPP packets are counted ?
meperuma
Looks to me it include both l2 and l3 as it counts for packets in and out of the interface,
I am not sure about your requirement but if your platform support, you can apply a MQC/policy-map on in and out with a class of l3 and l2, you should able to see the rate or packet counts
Thanks for your reply.
I have no specially requirements. I made bandwith test with a 10Gb generators (on the lan side) with different packet size to test the capacity of the equipments
So with 64 octets packets (ethernet) and a 2,5 Gb SDH link, the generator said that the maximum rate is 800 Mb/s before dropping. (LAN Ethernet side)
And on my router, on the interface POS, i had a 1,2 Gb/s rate.
There is the protocol overhead mecanism (IPSec, PPP/HDLC, SDH...). For this kind of packet, there are more overhead than payload.
So i just want to understand the value of the rate of the pos interface and which data are take in consideration...
