wan routing issue
I have 2 routers and 1 MLS. I have configured..
Router A is  internet router and its address is 2.2.2.2
router B as follows
ip cef
controller T1 0/0
framing esf
crc-threshold 1
linecode b8zs
channel-group 0 timeslots 1-32 speed 56
interface FastEthernet0/0
description ANH OLD LAN
ip address 172.18.100.10 255.255.255.0
speed 10
full-duplex
interface Serial0/0:0
description MPLS connection
ip address A.B.C.F  255.255.255.252
encapsulation ppp
interface FastEthernet0/1
description LAN Public IP
ip address 2.2.2.3.255.255.240
speed auto
full-duplex
router bgp 64513
no synchronization
bgp log-neighbor-changes
network X.X.X>X mask 255.255.255.240
redistribute connected
redistribute static
neighbor Y.T.R.R remote-as 65512
no auto-summary
no ip http server
ip classless
ip route 0.0.0.0 0.0.0.0 2.2.2.2
ip route 172.18.0.0 255.255.0.0 FastEthernet0/0
MLS as follows
mls flow ip destination
mls flow ipx destination
spanning-tree mode pvst
interface Vlan1
ip address 172.18.100.11 255.255.255.0
ip helper-address 172.18.100.1
interface Vlan2
description Wireless
ip address 172.18.101.11 255.255.255.0
interface Vlan200
ip address 192.168.5.1  255.255.255.0
ip classless
ip route 0.0.0.0 0.0.0.0 172.18.100.10
ip route 172.16.0.0 255.255.0.0 172.18.100.10
no ip http server
Router A's fa 0 interface and router B's  FastEthernet0/1 connected together via a switch.
router B's
interface FastEthernet0/0 and MLS switch connected as default vlan.
router B learn all the routes via BGP
my clients default gateway is 172.18.100.11.
I can access internet with internet router. and also I can ping to fa0/1 of router B via client PC. But only thing is I cannot access/ping  internet.
My question is why I cannot access internet with these configurations??
Quick reply highly appreciated.
Thank you
Chamara
shamax_1983
Level 3
Level 3
Hello Chamara,
You should have NAT setup for your Clients' internal subnet so it gets a public IP as it leaves your infrastructure.
When you try to ping Internet, the packet should have a routable (public) IP address.
In your case, as long as you ping your own infrastructure ( which you already have routes back for the private IP range you configured for your client ( 172.16.0.0 255.255.0.0 )) it will know how to get back.
But once it leaves your infrastructure and enters the Internet ( your ISP ) it will get dropped because Internet would not accept private IP addresses (RFC1918) as source addresses.
You can resolve this buy configuring NAT for your client's IP range on Router B
Let me know if you have more questions on this.
Also, please don't forget to rate/mark helpful answers.
Shamal
6 Replies 6
cadet alain
Can you ping f0/0 of Router A  from Router B  ? what gives a traceroute to 8.8.8.8 from the pc client ?
Regards.
Alain
I cannot access the internet router (Roouter A). But I can ping router B to roouter A fa0/0.  I can ping clients from the router B too.
Even I cannot trace route from MLS (switch ) too. it just showing stars...
Thank you
Chamara
milan.kulik
Level 10
Level 10
you might have forgotten to configure NAT for your clients using private IP addresses?
HTH,
Milan
shamax_1983
Level 3
Level 3
Hello Chamara,
Shamal
Damn.. I really forgot that.. Thank you so much Shamal and Milan.  much appreciated.
