WAN Routing Problem
Muhammad Younus
Community Member
Dear I am new here and beginner in routing and switching. We have two office locating in different cities. We have purchased VPN connection. The ISP gave us two VLAN address pool one for Internet and one for Data Link. I have successfully entered routes on both side routers and they can ping ping both LAN facing interface but unable to access devices inside LAN. Kindly help me plz...
Thank you...
2 Accepted Solutions
I think its asymmetric nat issue. Could you please create exented NAT access list and deny lan to lan subnet in NAT as below.
ip access-list ext NAT-POOL
deny ip 192.168.10.0 0.0.0.255 192.168.11.0 0.0.0.255
deny ip 192.168.11.0 0.0.0.255 192.168.10.0 0.0.0.255
permit ip 192.168.11.0 0.0.0.255 any
permit ip 192.168.10.0 0.0.0.255 any
Your reply in not clear please let me know from what IP you are able to ping which IP and from what IP you are not able to ping which IP.
are you able to ping  from any host  in subnet 192.168.10.0/24 to any host in subnet  192.168.11.0/24
are you able to ping  from any host  in subnet 192.168.11.0/24 to any host in subnet  192.168.10.0/24
8 Replies 8
Pawan Raut
Level 10
Level 10
It look like default route is missing on our office routers. Could you please share config of both router
Thank you for your response. I can ping LAN interfaces of both routers from either side but could not ping devices attached on both LAN side.
Here is the configuration of both sides.
Site 1 Configuration:
Building configuration...
Current configuration : 1768 bytes
version 12.3
service password-encryption
hostname site1
boot-start-marker
boot-end-marker
no network-clock-participate slot 1
no network-clock-participate wic 0
no aaa new-model
ip subnet-zero
no ip source-route
ip cef
ip dhcp excluded-address 192.168.10.1 192.168.10.100
ip dhcp pool SITE1_POOL
network 192.168.10.0 255.255.255.0
dns-server 192.168.10.17 208.67.220.220
default-router 192.168.10.1
ip audit po max-events 100
no ip bootp server
no ip domain lookup
interface FastEthernet0/0
no ip address
duplex auto
speed auto
interface FastEthernet0/0.1457
description Datalink
encapsulation dot1Q 1457
ip address 10.5.109.242 255.255.255.248
ip nat inside
no cdp enable
interface FastEthernet0/0.1458
description to Internet
encapsulation dot1Q 1458
ip address 210.2.155.114 255.255.255.248
ip nat outside
ip tcp adjust-mss 1450
no cdp enable
interface BRI0/0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet0/1
ip address 192.168.10.1 255.255.255.0
description to LAN
no ip unreachables
ip mtu 1450
ip nat inside
ip tcp adjust-mss 1400
duplex auto
speed auto
interface Ethernet1/0
no ip address
shutdown
half-duplex
ip nat inside source list NAT-POOL interface FastEthernet0/0.1458 overload
no ip classless
ip route 0.0.0.0 0.0.0.0 210.2.154.113
ip route 10.5.109.16 255.255.255.248 10.5.109.241 (Provided by ISP)
ip route 192.168.11.0 255.255.255.0 10.5.109.241
ip http server
no ip http secure-server
ip access-list extended NAT-POOL
no cdp run
line con 0
line aux 0
line vty 0 4
end
Site 2:
Current configuration : 2055 bytes
version 15.1
no service pad
hostname Site2
boot-start-marker
boot-end-marker
no aaa new-model
dot11 syslog
no ip source-route
ip cef
no ip bootp server
license udi pid CISCO2821 sn FHK1025F2DJ
redundancy
controller T1 0/0/0
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
interface GigabitEthernet0/0.2319
encapsulation dot1Q 2319
ip address 10.5.109.18 255.255.255.248
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/0.2320
description to the Internet
encapsulation dot1Q 2320
ip address 210.2.154.106 255.255.255.248
no ip unreachables
ip nat outside
interface GigabitEthernet0/1
description LocalLAN
ip address 192.168.11.1 255.255.255.0
no ip unreachables
no ip proxy-arp
ip flow ingress
ip nat inside
duplex auto
speed auto
no ip classless
ip forward-protocol nd
no ip http server
ip flow-cache timeout inactive 10
ip flow-cache timeout active 5
ip flow-export version 9
ip flow-export destination 192.168.11.206 9991
ip flow-top-talkers
top 50
sort-by bytes
ip nat inside source list NAT-POOL interface GigabitEthernet0/0.2320 overload
ip route 0.0.0.0 0.0.0.0 210.2.155.105
ip route 10.5.109.240 255.255.255.248 10.5.109.17
ip route 192.168.10.0 255.255.255.0 10.5.109.17
ip access-list standard NAT-POOL
permit 192.168.11.0 0.0.0.255
permit 192.168.10.0 0.0.0.255
ip access-list standard wr
no cdp run
control-plane
line con 0
line aux 0
line vty 0 4
scheduler allocate 20000 1000
end
Thank you for reply, I have created the list on both routers, I am amazed I can ping only device from 192.168.10.0 and router's IP. I cant ping any device on 192.168.11.0 from 192.168.11.0 except 192.168.10.1
Sorry to bothering help please.
Ok Sorry for that. I am able to ping 192.168.11.1 from 192.168.10.0/24 and able to ping 192.168.10.1 from 192.168.11.0/24. Both ips are on LAN facing interface of the router. But I am unable access any machines on both LAN subnet i.e. 192.168.10.0/24 and 192.168.11.0/24. Internet is working on both sites.
I hope you got my point.
Let me create this in my test lab I will get back to you tomorrow
Thank you so much for your help bro it is working now. Your first diagnose was correct it was an Asymmetric NAT issue.
Best regards.
