WAN routing
aadilovic
Level 3
Level 3
hello
I have router 2801 with two WAN link.
One is with static IP address, and the other is with dynamic IP.
One subnet (management user) use one WAN link (static IP),
second subnet use second WAN link.
I want to do these.
If one WAN link go down (link with static IP),
the other will route traffic for that subnet.
All traffic should go across other, active, link.
and when it came back, it will again route traffic for it subnet.
I hope you understand me.
How can i do that?
I checked your config one more time. It's failing because you aren't NATng for those addresses.
You have a "source list G-nat" for dialer0 and G-nat ACL isn't listing those IPs for translation.
HTH,
__
Edison.
13 Replies 13
Edison Ortiz
I believe I understand you, but I will understand you better if you post the config from the router. I believe you have a PBR configured on this device since you are doing source based routing but I want to make sure before giving you a recommendation.
__
Edison.
ok.
here is config...
regards..
As suspected, you are using PBR.
The solution is simple. Simply add another set statement within your current route-map pointing to F0/0 interface.
The route-map will try the destination in order. Currently you have:
set interface FastEthernet0/1
set ip next-hop 80.65.75.1
just modify it like:
set interface FastEthernet0/0
HTH,
__
Edison.
ok
i will try this. hope it will resolve my problem.
thank you again...
i will post you the results.
regards
hello
i was did as you say
after re-configuring route map, it arrange line like this (little difference related to your post):
route-map zaCito permit 10
match ip address zaCito
set interface FastEthernet0/1 FastEthernet0/0
is this ok, or there are tricks how to do this...
regards
Interesting, the parser arranges the commands. Well, anyway - you have F0/1 before F0/0 so it should work. Have you test it ?
__
Edison.
yes, without success.
i was shoot down fa 0/1 and test it.
cant go out across other link.
i think i need another ip next hop, but how, it is internet packet with dynamic IP address...
HTH,
__
Edison.
ok
i will make nat and try again
will post you results
is this that:?
ip access-list extended G-nat
permit ip 172.16.3.0 0.0.0.255 any
permit ip 172.16.1.0 0.0.0.255 any
permit ip 172.16.4.0 0.0.0.255 any
deny ip any any
i got a result.
i was did exactly as You say:
route-map zaCito_rmp permit 10
match ip address zaCito_acl
set ip next-hop 80.65.75.1 89.146.128.1
and i was add second ip next gateway.
Configure nat as You say and its work.
when shut fa 0/1 traffic go out through dialer
0.
NAT did as you say.
I thin that is it.
Thank You lot.
this is very helpful for me.
one more question:
will this config be ok...
route-map zaCito_rmp permit 20
set ip next-hop 89.146.128.1
regards
one more question:
Yes, nested route-map will work as well.
thanks again, a lot...
i did nested route-map.
its work fine, for now.
thank for your time.
best regards
