want to access nated Ip from Inside
hai_nit2
I have one firewall ASA5510, and I configured NAT from inside IP to Ouside IP on ASA5510, and I want to access that Outside Ip from Inside,Please Help me, I am trying from last 1-week but still I am unable to do that.
scottmac
Level 10
Level 10
If you don't have one already, and you need this to work from a bunch of machines inside, set up a DNS server for the inside network with the correct inside NAT address for the internal resources (in addition to caching the external references).
If this is just for your machine, then edit the hosts file with the internal address mapped to the external dns name.
The hosts file is under SYSTEM32\ETC\DRIVERS (which starts under the directory name of either WINDOWS or WINNT)
There are examples in the hosts.sam file, ust edit your hosts in following that format and save it as "hosts" (no .sam extension).
Windows searches that file for address resolution before sending a DNS request (for *nix, it uses /etc/hosts).
Good Luck
Scott
HEllo Scott,
Thanks for your reply,
I changed tht host file but still same. I am not able to ping ,
hey I just wanted to know that in ASA I need to change anything or any access list for that.If yes please tell me the command.
Nitin
You need to create another static. Here's a link that explains how/why. If you need more help, let us know.
http://blogs.interfacett.com/mike-storm/2006/6/29/bidirectional-nat-on-a-cisco-pix-or-asa.html
HTH and please rate.
