06-27-2007 10:08 AM - edited 03-03-2019 05:38 PM
Our remote office is installing a Sharp AR-M207 (MFP). The tech configured the network settings, and I can ping it with no problem. However, each time I attempt to interact with the webserver, (Internet Explorer over the WAN) the router reboots. I thought it might be a power issue, but the MFP is now plugged in away from the router. Once the router came back up, I ran a couple ip scans over the WAN to try and load up the router a bit. Next I VNC'd to one of the LAN workstations and used it to interact with the webserver and had no problems. Then I tried to connect to the webserver from here (over the WAN) and the router rebooted again. It's happened four times so far. We have unplugged the MFP from the network and I'm monitoring the link to verify the WAN link connectivity. The tech is planning to do a firmware update on the NIC if nothing else shows up. Anybody ever see this before? Thanks.
06-27-2007 11:00 AM
Sounds very interesting...
Generally everytime a Router reboots, it logs the reason in the sh ver.
May I request you to paste the output from sh ver of the router in order to better understand what might have caused the reboot.
Wilson Samuel
06-27-2007 11:12 AM
This is all that I found in the log. It was the same for each reboot...
*Jun 27 11:24:56.692: %LINK-5-CHANGED: Interface FastEthernet0/1, changed state to administratively down
*Jun 27 11:24:57.864: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Jun 27 11:24:58.420: %SYS-5-RESTART: System restarted --
Cisco IOS Software, C2600 Software (C2600-JK9S2-M), Version 12.3(14)T4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Thu 08-Sep-05 14:49 by kehsiao
*Jun 27 11:24:58.424: %SNMP-5-COLDSTART: SNMP agent on host XXXX_VPN is undergoing a cold start
*Jun 27 11:24:58.508: %CRYPTO-6-ISAKMP_ON_OFF: ISAKMP is ON
*Jun 27 11:24:58.572: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host xxx.xxx.xxx.xxx started - CLI initiated
*Jun 27 11:24:59.424: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to down
*Jun 27 11:25:05.660: %LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed state to up
*Jun 27 11:25:11.660: %SYS-6-LOGGINGHOST_STARTSTOP: Logging to host xxx.xxx.xxx.xxx started - reconnection
*Jun 27 11:26:14.493: %LINK-3-UPDOWN: Interface ATM0/0, changed state to up
*Jun 27 11:26:17.493: %LINEPROTO-5-UPDOWN: Line protocol on Interface ATM0/0, changed state to up
*Jun 27 11:26:19.997: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnelxxx, changed state to up
*Jun 27 11:26:20.973: %ATM-5-UPDOWN: Interface ATM0/0, Changing autovc 8/35 to PVC activated.
*Jun 27 11:26:21.961: %CRYPTO-4-RECVD_PKT_INV_SPI: decaps: rec'd IPSEC packet has invalid spi for
destaddr=xx.xx.xxx.xxx, prot=50, spi=0x7xxxxxxx(xxxxxxxxxx), srcaddr=xxx.xxx.xxx.xxx
*Jun 27 11:26:29.493: %CRYPTO-4-IKMP_NO_SA: IKE message from xxx.xxx.xxx.xxx has no SA and is not an initialization offer
*Jun 27 11:26:34.998: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnelxxx, changed state to down
*Jun 27 11:26:39.998: %LINEPROTO-5-UPDOWN: Line protocol on Interface Tunnelxxx, changed state to up
06-27-2007 11:24 AM
Thanks for the info, could you also paste the sh ver output, actually I'm looking for something like this(enclosed in the stars):
Cisco 7206VXR (NPE400) processor (revision A) with 114688K/16384K bytes of memory.
Processor board ID 26811579
R7000 CPU at 350MHz, Implementation 39, Rev 3.3, 256KB L2 Cache
6 slot VXR midplane, Version 2.6
***Last reset from power-on****
PCI bus mb0_mb1 (Slots 0, 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb0_mb1 has a total of 890 bandwidth points.
The set of PA-2FE, PA-POS-2OC3, and I/O-2FE qualify for "half
bandwidth points" consideration, when full bandwidth point counting
results in oversubscription, under the condition that only one of the
two ports is used. With this adjustment, current configuration on bus
mb0_mb1 has a total of 690 bandwidth points.
This configuration has oversubscripted the PCI bus and is not a
supported configuration.
PCI bus mb2 (Slots 2, 4, 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 300 bandwidth points
This configuration is within the PCI bus capacity and is supported.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
And any other info that it might have, moreover I would also like to run a Bug Toolkit on the IOS version.
Kind REgards,
Wilson Samuel
06-27-2007 11:30 AM
Thanks for your interest. Here's the "sh ver"
XXXX_VPN#sh ver
ROM: System Bootstrap, Version 12.2(7r) [cmong 7r], RELEASE SOFTWARE (fc1)
XXXX_VPN uptime is 1 hour, 56 minutes
System returned to ROM by error - a SegV exception, PC 0x81E6781C at 11:24:56 MDT Wed Jun 27 2007
System restarted at 11:29:26 MDT Wed Jun 27 2007
System image file is "flash:c2600-jk9s2-mz.123-14.T4.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
Cisco 2621XM (MPC860P) processor (revision 0x100) with 127308K/3764K bytes of memory.
Processor board ID JAD06500GWT (2787821242)
M860 processor: part number 5, mask 2
2 FastEthernet interfaces
1 ATM interface
32K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
06-27-2007 11:48 AM
The router had crashed due to the SegV exception and I strongly suspect either Memory issue or Bug.
You may like to cross check for any known Bugs by either pasting the sh stacks info to let us help you.
Or alternatively you may open up a TAC Case, in case if its not a known bug yet.
You may also like to visit the following URL
http://www.cisco.com/en/US/customer/products/hw/iad/ps397/products_tech_note09186a00800b4447.shtml
I hope this helps,
Please rate if it helps,
Kind Regards,
Wilson Samuel
06-27-2007 12:24 PM
Here is the stack info, but maybe not enough to diagnose the problem? I put it into the output analyzer and it might be a bug. We have been running this version for about a year now and never had this problem until today.
XXXX_VPN#sh stacks
Minimum process stacks:
Free/Size Name
5524/6000 Clock Update Proc
5584/6000 SPAN Subsystem
59388/60000 script background loader
2568/3000 allegro libretto init
11000/12000 Router Init
3656/12000 Init
5412/6000 RADIUS INITCONFIG
2576/3000 Rom Random Update Process
34924/36000 TCP Command
10156/12000 Virtual Exec
Interrupt level stacks:
Level Called Unused/Size Name
1 532353 6072/9000 Network interfaces
2 0 9000/9000 Timebase Reference Interrupt
3 0 9000/9000 PA Management Int Handler
6 14 8920/9000 16552 Con/Aux Interrupt
7 2303380 8912/9000 MPC860 TIMER INTERRUPT
Spurious interrupts: 1
System was restarted by error - a SegV exception, PC 0x81E6781C at 11:24:56 MDT Wed Jun 27 2007
Image text-base: 0x80008098, data-base: 0x826E9AC0
Stack trace from system failure:
FP: 0x84AAC010, RA: 0x81E6F090
FP: 0x84AAC058, RA: 0x82414BBC
FP: 0x84AAC0A0, RA: 0x82410CB0
FP: 0x84AAC0C8, RA: 0x80C22194
FP: 0x84AAC0E0, RA: 0x809E80FC
FP: 0x8453C7B8, RA: 0x80C11C54
FP: 0x8453C7C8, RA: 0x80C11C54
FP: 0x8453C800, RA: 0x809E81BC
******* Information of Last System Crash **********
The last crashinfo failed to be written.
Please verify the exception crashinfo configuration
the filesytem devices, and the free space on the
filesystem devices.
Using crashinfo_FAILED.
%Error opening crashinfo_FAILED (No such file or directory)
06-27-2007 01:52 PM
Can you take the o/p of sh proc mem and continue to watch it. Are you observing any memory leaks in the sense any process holding the memory and also see for any access-list which has the HTTP port mapped which are logging the packet matched. this also can eat up memory and cpu process. Also check for bugs associated with the IOS. Certain IOS trains have some memory leak issues.
I hope my hints have give you some idea.
Thanks and Regards,
Srinath.Muralidharan
Cable&Wireless
06-27-2007 02:25 PM
Thanaks for chiming in Srinath. The router is working fine right now, as it has for the last year. The reload only happens when I attempt to access the webserver on the MFP.
