05-06-2010 12:28 PM - edited 03-04-2019 08:24 AM
Hi all....hope i didnt miss anything simple here...but have an nbar issue...sorry if this is long winded....just wanted to provide info.
i have ip nbar protocol-discovery on my interfaces along with cef. when i do a sh ip nbar protocol-discovery stats bit-rate top 10....i get the following output....with no data on s0/0
however...when i do the command with out stats bit-rate i get data on s0/0: (Ignore the edonkey....i think it is ftp...is on a lab set up so I know there is no file sharing going on).
the lab is set up with 2 routers connected via t1.
I think it is messing with my testing of traffic shaping ....i am using the following class maps and policy map on my serial 0/0 but am not getting the shaping i would expect.
Class Map match-any PRIORITY_BUSINESS (id 12)
Match access-group name HTTP_ADP
Match access-group name SOARR
Match access-group name TELNET
Match access-group name FTP
Class Map match-any WWW (id 16)
Match access-group name HTTP_HTTPS
Class Map match-any VOICE_OUT (id 10)
Match access-group name RTP
R2-3725#sh policy-map
Policy Map EGRESS_TRAFFIC
Class DAY
Traffic Shaping
Average Rate Traffic Shaping
CIR 1500000 (bps) Max. Buffers Limit 1000 (Packets)
service-policy HQ_REMOTES
Class LIMA
Traffic Shaping
Policy Map HQ_REMOTES
Class VOICE_OUT
Bandwidth 30 (%) Max Threshold 64 (packets)
Class PRIORITY_BUSINESS
Class WEB
Bandwidth 20 (%) Max Threshold 64 (packets)
Class class-default
appreciate any advise you have.
05-07-2010 06:31 AM
figured out the issue....appears to have been a bug in the ios code i was running...upgraded ios and issue has gone away.
05-08-2010 02:59 AM
Hello Mark,
you have been kind in providing a feedback on this issue
this makes this thread a complete story.
if you like you can add the Cisco bug-id that was causing this issue
Best Regards
Giuseppe
