12-13-2010 01:40 AM - edited 03-04-2019 10:45 AM
pls answ to me, what ios for 827-4v from 12.4 can i use for IPSEC+ddns?
i tested some from 12.4 but normaly working only 12.3(26)GD, but i want ddns feature? some from 12.4 is working with tracebacks, other is not loading - with error (loadprog: error - program section linked to illegal address)
12-15-2010 04:36 PM
How much memory do you have? The 827-4v comes default with 24 MB of DRAM. These 12.4 images require 48 MB of DRAM.
........Mike
12-15-2010 10:04 PM
48/12
12-16-2010 11:05 AM
To answer your question more completely, there are two tools available on cisco.com that help in identifying IOS image that are supported on specific hardware and with specific features.
They are the feature navigator tool:
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
And Software Advisor:
http://tools.cisco.com/Support/Fusion/FusionHome.do
Using these tools I figured out that this router is EOL.
The last date of support was May 31, 2010.
As a result of the system going EOL support for it would fall out of newer IOS code.
Using either of the feature and software tools you will see that the last 12.4 image supporting this hardware with the IPSEC and Dynamic DNS features would be 12.4(5c) IP/FW/VOICE PLUS 3DES feature set or image name c820-k9osv6y6-mz.124-5c.bin
You should replace the hardware with equipment that continues to be supported as it is obsolete.
........Mike
Remember if your question is answered you should update the question status.
12-19-2010 10:48 PM
thanks i will try this version.
