What is different of cf memory card 256MB, between part number 16-2647-04 and 17-7467-01 ?
ogremode
Is it compatibility ?
Thank you
Philip D'Ath
One probably replaced the other.
Basically any compact flash card under 2GB works.  I usually partition it while plugged into the router, then take it out of the router and format it FAT16 on a PC.
Annoying IOS formats a blank card using FAT32, while ROMMON can only boot from FAT16.
