what is the difference about these 3 commands.
att-sgcops
Can someone tell me the difference (I try to filter the routing based on AS-PATH):
neighbor 204.12.1.254 filter-list 1 out
ip as-path access-list 1 deny _254_
neighbor 204.12.1.254 route-map no254 out
route-map no254 deny 10
match as-path 1
route-map no254 permit 20
ip as-path access-list 1 permit _254_
route-map no254 permit 10
match as-path 1
devang_etcom
Level 7
Level 7
neighbor ipaddress filter list...this command sets up an AS path access list that filter BGP routes sent to or received from a specific neighbor...and out keyword applies filter to outgoing routes...
means here your total configuration post by you is used for the route filtering...
hope this will help you
rate this post if it helps
regards
Devang
devang_etcom
Level 7
Level 7
ip as-path accesslist...
this command used to build an access list for the BGP AS paths...you can have this list appled to aneighbor with the filter list option to the neighbor command as you have done...
ip as-path access-list deny_254_
this command denies the routes that include AS 254...
regards
Devang
olorunloba
Level 5
Level 5
This uses a filter-list to filter all routes that have passed through AS 254. But because there is an implied deny all at the end of an access-list, all other routes are denied as well, and nothing is advertised. To correct this,
include ip as-path access-list 1 permit .*
match as-path 1
This uses a route-map deny the advertising routes that have passed through AS 254. The line route-map no254 permit 20 ensures that the other routes are not denied and advertised.
match as-path 1
This permit the advertisement of only routes that have passed through AS 254. Other routes are denied.
Look in the following links for more example
http://www.cisco.com/warp/public/459/26.html
