What is the maximum number of OSPF routers can do load balancing?
Maivoko
Number of DR and BDR in one OSPF area - Cisco Community
this link said only one DR and one BDR, does it mean one kind of traffic can only have maximum 2 OSPF routers to load balancing traffic to Internet ?
2 routers traffic A, 2 routers traffic B, 2 routers traffic C
BGP + OSPF routers is a multiple of 2 when core switch router divided traffic using MSTP and using EIGRP with route map to divide traffic with source subnet to traffic A routers and traffic B routers and traffic C routers ?
Hello
Your OP is not that very clear
However all routers running OSPF/BGP can do load share, Equal Cost MultiPath (ECMP) is the LB method they can use , With OSPF by default its applicable to 4 paths and upto a maximum of 16.
Kind Regards
Paul
6 Replies 6
Hello
Kind Regards
Paul
Joseph W. Doherty
You misunderstand - there is no direct correlation between DR/BDR and load balancing.
"What is the maximum number of OSPF routers can do load balancing?"
It's the same number as how many OSPF routers you have.
I got it.
DR and BDR may not be gateway
Oh, you didn't want to know maximum number of OSPF routers, as asked, but maximum number of same destination OSPF routes?  Ah, well as provided by @paul driver, for OSPF the default is 4.  However, although Paul notes maximum is 16, that's true for most current IOS versions, I've read some now accept 32 (IOS-XR?); earlier versions, I recall (?) supported maximum being less, e.g. 6, in version 11. (Also, the default and maximum can vary with other vendors; RFC might not have defined a default nor maximum.)
Also, BTW, DR/BDR can be a gateway, at least as "gateway" is commonly defined.
Past colleague told DR as gateway.
I had already known DR may not be gateway, I can use
sh ip route to find 0.0.0.0 default gateway
to compare whether it is DR
you said maximum number of same destination OSPF routes default 4 maxmium 16
so, what is maximum number of different destination OSPF routes ?
there are two type of traffic
data traffic and routing traffic
routing traffic with elect DR/BDR where instead of each router send/receive LSA the router elect DR/BDR and send LSA to only DR/BDR and DR/BDR will forward it to all routers.
later there is Data traffic which can be load by any routers in same broadcast.
