What is the most popular deployment for metro network
Odys (CSC)
Hi there,
I'm wondering what's the most common deployment of metro network between two physically separated buildings ?
Should they have the same subnet ? or a different one at each side ?
thx
Garry
Richard Burts
Garry
I have seen it implemented both ways, with the same subnet of both sides (especially if the provider supports Q in Q tunneling) or with separate subnets on both sides. I would say it is more common to have separate subnets on both sides.
Rick
Rick
Richard Burts
Garry
Rick
Rick
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages wha2tsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
Like Rick, I've seen both.  Much often depends whether there's a real "need" to extend L2 and/or equipment already on-hand.
