what's the difference between FMANFP-6-IPV6ACCESSLOGP and IPV6_ACL-6-ACCESSLOGP?
xidasd
Most cisco documents say that the "IPV6_ACL-6-ACCESSLOGP" log will be logged as a result of ACL logging. But in my router, the logged message is "FMANFP-6-IPV6ACESSLOGP: R0/0: fman_fp_image: list~~" and also it does not record MAC address of source even if ACL is configured "log-input"
Does this difference depend  router version? My router is ISR 4321 and it seems that the router version used for cisco documents are 2911 router.
2 Accepted Solutions
Giuseppe Larosa
Hello @xidasd ,
you can use the message decoder tool
Message Decoder tool at: https:/​/​www.cisco.com/​cgi-bin/​Support/​Errordecoder/​index.cgi.
However, ISR 4000 series routers have an on board switching fabric that is missing on C2911 so that FMAN may mean fabric manager.
Hope to help
Giuseppe
Hello @xidasd ,
the tool explains only error messages.
The reason why you don't see MAC addresses even with log-input keyword may be a limitation on the device or feature.
However, if you are using the EUI-64 method to create the host portion of each device host IPv6 address the MAC address can be found using the EUI-64 operations in reverse order to get the 48 bit MAC address
Hope to help
Giuseppe
Giuseppe Larosa
Hello @xidasd ,
Hope to help
Giuseppe
You means only way to view Source MAC address is to use decoder tool? Is there other way to display source MAC address on native log file?
Hello @xidasd ,
Hope to help
Giuseppe
