10-18-2008 12:47 AM - edited 03-03-2019 11:58 PM
Hello everyone!
this may seem a silly question. But, i am new to this market & want to know what interface does 1750 have on its WAN port. And is there any way to change it??
10-18-2008 04:25 AM
Hello Rahul,
use the following link:
http://www.cisco.com/en/US/products/hw/routers/ps22/products_data_sheet09186a0080092102.html
you can add/change WIC modules
Hope to help
Giuseppe
10-18-2008 06:23 AM
1750 is a modular router which comes with one 10/100 ethernet interface by default.
It has One VIC and Two VWIC slots [empty], where you can insert modules as and when required.
Refer to Table 3 & 4 in the following link for the supported modules -
http://www.cisco.com/en/US/products/hw/routers/ps221/products_data_sheet09186a0080092102.html
-> Sushil
10-18-2008 08:27 AM
Thanks buddy!
10-18-2008 08:42 AM
I have another question.
Do 1750 can have 2 WAN ports. As i require 1 WAN port with smart serial interface & 1 WAN port with Ethernet interface. With 1 LAN port with Ethernet interface.
10-18-2008 08:46 PM
Yes you can have. You need to have a WIC-1T module on the router to get the Serial Interface. If you are really interested in getting smart serial then you need WIC-2T.
The in built ethernet interface would [rovide you anther WAN connectivity.
Use WIC-1ENET for LAN connectivity.
Check the availability of WIC-1ENET, not sure if its still available.
-> Sushil
10-18-2008 09:30 PM
thanks bro.
its done.
rahul
10-18-2008 11:29 PM
No Problem Rahul. Glad that I was of a little help.
-> Sushil
