When connecting two serial link on WIC-2T, Connection Breaks
shoebwk
I have 1841 router with WIC-2T. S0/0/0 is connected to Branch-A and is working properly. As soon as i connected second V35 cable to S0/0/1, my S0/0/0 link to the branch-A breaks and there is TTL expired response from S0/0/0 interface. The S0/0/1 is not yet active at other end. My config to serial link is below.
interface Serial0/0/0
ip address 10.1.1.1 255.255.255.252
ip helper-address 10.116.2.5
interface Serial0/0/1
ip address 10.1.2.1 255.255.255.252
clock rate 2000000
What could be the reason.?
SK
hoogen_82
Level 4
Level 4
Don't connect the cable on a working router. Switch of the router and then connect the new cable and establish connection.
Cheers
Hoogen
I did that but it works for sometime and then suddenly the s/0/0/0 link goes down.
regards
SK
Well can u attach the show interfaces log when the links are up. Also do collect logs from the console "show log" and attach the output here.
Cheers
Hoogen
deilert
Level 6
Level 6
you may need to add or tweak the network clock participate command.
