Where is running-config located at in ASR9K?
wfqk
Level 5
Level 5
In regular ios, running-config file is located at nvram. Anyone can tell where is running-config located by default at in ASR9K? Thank you
Julio E. Moisa
It should be stored at the NVRAM as well.
>> Marcar como útil o contestado, si la respuesta resolvió la duda, esto ayuda a futuras consultas de otros miembros de la comunidad. <<
Thanks for your reply.
What command can we use to see the config file located at NVRAM in asr9k? or see where it is located?
Running configuration is located in RAM.
Hi, you could use the command: Dir <location> , example:
#dir ?
/all List all files
/ena Recognize sub directories
/recurse Recursively list subdirectories encountered
WORD file name
bootflash: bootflash: file system
disk0: disk0: file system
disk0a: disk0a: file system
disk1: disk1: file system
disk1a: disk1a: file system
harddisk: harddisk: file system
harddiska: harddiska: file system
harddiskb: harddiskb: file system
location Fully qualified location specification
nvram: nvram: file system
dir nvram:
Also you could verify the bootflash:
dir bootflash:
Hope it is useful:
