Where to apply random-detect for WAN interface
Dan Verzaal
Level 4
Level 4
Hi everyone,
My network team has been having a discussion lately on where 'random-detect' should be placed.  For a long time we had it in the scavenger class and the default class.  I've personally never heard of it being in more than one class.  I think it should be in the default-class only.
So this raised more questions:
1. can it be in both classes? If yes, Are there any problems with this?'
2. Should it only be in one class?
3. should it be in the Parent policy TEST_ETH10000 under class-default so it applies random-detect to all classes in the child policy TEST-MPLS-QoS ??
How are other enterprises implementing random-detect?
! Configure child policy
policy-map TEST-MPLS-QoS
class Voice
priority 1000
class Video
bandwidth remaining percent 40
class VVSignaling
bandwidth remaining percent 24
set ip dscp cs3
class NetworkSupport
bandwidth remaining percent 5
class Scavenger
bandwidth remaining percent 1
set ip dscp cs1
police rate percent 40
random-detect ??????
class class-default
bandwidth remaining percent 30
set ip dscp default
! Configure Parent policy
policy-map TEST_ETH10000
class class-default
  shape average 9500000
   service-policy TEST-MPLS-QoS
! Apply to WAN interface
interface Gig1/1
description connection to MPLS ISP
service-policy output TEST_ETH100000
! Class-maps
class-map match-any Voice
match ip dscp ef
class-map match-any Video
match ip dscp af41 af42
class-map match-any VVSignaling
match ip dscp cs3
match ip dscp af31
class-map match-any NetworkSupport
match ip dscp cs6
match ip dscp cs2
match access-group name NetworkControl
class-map match-any Scavenger
match ip dscp cs1
match access-group name Scavenger-Protocols
thanks,
Dan
CCIE RS 34827
CCIE RS 34827
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
#1 Sure, it can be used in both classes or multiple classes.  Possible problems, sure too - it's an "it depends" kind of answer.
#2 Another "it depends".  Doesn't have to be.  If FQ is supported on the platform I recommend that over RED.
#3 No, as parent policy is pushing queuing to child policy.
Re: other Enterprises
Don't know, but most, I think, don't really understand how to use RED effectively, which can be surprising difficult to accomplish (except for tiered drop points).  For example, RED was designed to interact with (equal valued) flow rate adaptive traffic, such as TCP.  If your class-default or scavenger has other than flow adaptive traffic, you're probably suboptimally using RED.  Or, for example, do you allow RED to target non-piggy-backed ACK packets?  If so, are you doing that by design or just allowing RED to target all class traffic?  If the latter, again, you're probably suboptimally using RED.
Besides many not really understanding RED, many don't, I also think, understand the finer nuisances of QoS.  For example, your scavenger class is provided 1% remaining bandwidth but is also policed at 40%.  Why the policer if the scheduler effectively is providing this class available bandwidth.  I.e. why limit available bandwidth, unless you pay extra for exceeding 40% bandwidth.  But if if you did, why use a policer and not a shaper?
