Which Cisco Network Management tool can support GRE tunnels for 2900?
We have many routers and DMVPN between them.
We are looking for a Cisco Network Management solution to monitor that tunnels.
We have Prime Network 3.10, but it don't support GRE tunnels for 2900 routers (http://www.cisco.com/en/US/docs/net_mgmt/prime/network/3.10/supported/vnes/chapCiscorouters.html#wp898472 table IMO-ITunnelGRE)
What other Cisco product can support these tunnels?
Kelvin Willacey
Level 4
Level 4
Although I am not a big fan of Cisco management type tools, ACS being the only exception, I think Cisco Security Manager would be your option.
VPN Wizard
Provides easy configuration of site-to-site, hub-and-spoke, full-mesh, and extranet VPNs
Support for Common VPN Deployment Scenarios
Enables common VPN deployment scenarios with support for Group Encrypted Transport VPN (GET VPN), Dynamic Multipoint VPN (DMVPN), and generic routing encapsulation (GRE) IP Security (IPsec), both with dynamic IP and hierarchical certificates
http://www.cisco.com/en/US/prod/collateral/vpndevc/ps5739/ps6498/data_sheet_c78-727090.html
