which IOS support BSTUN
devang_etcom
Level 7
Level 7
hello to all ...
can any one guide me which IOS i have to install in my router to configure BSTUN?
regards
Devang
5 Replies 5
pkhatri
Level 11
Level 11
What model router do you have ?
Paresh
i am having 2500 2600 and 36XX series of router and i want to test it out in lab and then want to implement in field so i have to find out cost effective solution so please tell me if you have any lower level device supported the same technology.
regards
Devang
Hi Devang,
On most of these platforms, you will need the IP Plus feature set. Also, if you have an IOS later than 12.0, you should be fine.
Hope that helps - pls rate the post if it does.
Paresh
wstargardt
Do the Cicso 2900 routers also support BSTUN, particularly the 2901?
I checked the Feature Navigator on the Cisco web site and it indicates that the 2901 does support BSTUN if running a 15.1T version with the Universal (Data and Security) feature set.
Rick
Rick
