which solution is correct?
att-sgcops
If I was required to log all the telnet session to router R1 comming from outside with the following network topology:
outside -------(S0/0, IP addr 11.1.1.1) R1 (e0/0)-----inside
1: interface s0/0
ip access-group Incoming in
ip access-list extended Incoming
permit tcp any 11.1.1.1 eq telnet log
permit ip any any
2: line vty 0 4
access-class incoming
ip access-list standard incoming
permit any log
Which way is correct? Or both are correct?
thanks
Roberto Salazar
Level 8
Level 8
Number two will also log telnet from internal since the access-list is applied on the VTY, and the access-list permits all. In other words, it would log telnet coming from e0/0 or inside too. so, it does not meet the requirement.
Please rate helpful posts.
Roberto Salazar
Level 8
Level 8
