Cisco7204VXR-
aghm
I have already configured a 7200 with this options:
1.Cisco 7204 VXR
2.NPE-G2
3.PA-MC-8TE1+
But it is a problem with NPE-G2.
Would you Please send me a good technical document about it.
6 Replies 6
jackyoung
Level 6
Level 6
Could you please explain the problem in details ? Cannot regonize it ? Please provide "sh ver" & "sh cont".
I tried to use configuration tool to build a setup and find the NPE-G2 does not compatible w/ PA-MC-8TE1+. Therefore, you have to use another PA, e.g. PA-MCX-8TE1.
Hope this helps.
Very thanks for your kindly attention.I am consultant of a telecom company and I am confused if NPE-G2 support PA-MC-8TE1+ or not.
Checked your profile, you should know how to use configuration tool in Cisco web.
The PA-MC-8TE1+ should work w/ 7204VXR. However, it does not work w/ NPE-G2, so if you want to use NPE-G2, you need another MC module. Otherwise, use other NPE module.
