Why can't I ping the loopback interfaces?
news2010a
Level 3
Level 3
Hi, can you help me with this.
From WG4R3 I can't ping Lo0 and Lo1 on WG4R2 and vice and versa. I advertise the respective networks Lo0 and Lo1 via OSPF, so I am not sure if I can understand what's going on. My ultimate goal is to ping lo0:192.20.11.1 on router "Good".
In R2, you have the following OSPF configuration:
router ospf 4
log-adjacency-changes
network 192.168.4.0 0.0.0.3 area 0
network 192.168.34.0 0.0.0.255 area 0
network 197.4.2.0 0.0.0.255 area 0
network 197.4.3.0 0.0.0.255 area 0
And you have the following L3 interfaces:
interface Loopback0
ip address 197.4.2.1 255.255.255.0
interface Loopback1
ip address 197.4.3.1 255.255.255.0
interface Ethernet0
ip address 192.168.4.5 255.255.255.252
interface Serial0.1 multipoint
ip address 192.168.4.2 255.255.255.252
interface Serial0.2 point-to-point
ip address 192.168.34.1 255.255.255.0
Noticed, how E0 is missing within the OSPF process? That's the reason there is no neighbor between R2 and R3. You need:
network 192.168.4.4 0.0.0.3 area 0
On R2.
As for changing the frame-relay interface type, you have 2 options:
1) Delete the interface with:
no interface Serial0.1 multipoint
then reboot and recreate the interface.
2) Create another interface with a different number:
interface Serial0.10 point-to-point
frame-relay interface-dlci 221
HTH,
__
Edison.
Edison Ortiz
Based on the output provided,
WG4R3#show ip ospf neig
Neighbor ID Pri State Dead Time Address Inter
197.4.7.1 0 FULL/ - 00:00:30 192.168.4.10 Seria
I don't see WG4R2 listed as OSPF neighbor, just WG4R4 is listed.
Verify connectivity between these routers and please post the WG4R2 config for further help.
__
Edison.
news2010a
Level 3
Level 3
Please find attached run config for all routers (WG4R1 thru WG4R4).
One thing that I noticed is that on WG4R2, there is a s0.1 interface configured as multipoint. I tried to do it as 's0.1 point-to-point' but that was not accepted by the IOS. I got message saying that 'type cannot be changed'.
router ospf 4
interface Loopback0
interface Loopback1
interface Ethernet0
On R2.
HTH,
__
Edison.
You rule! That was it. Thanks!!!
