Why can't I telnet to my loopback0 interface?
Ian001
I set up Router0 with an extended ACL to permit telnet into loopback0 (172.20.0.1) on interface s0/1/0. I was originally able to telnet from Router1, then I tried to make some funky additions to my network and when I tried to telnet from Router1 afterwards I got "remote host not responding" message. Any ideas what the cause might be?
I've tried:
- shutting and no shutting the serial interfaces
- removing the ACL from int s0/1/0 on Router0 - still did not allow telnet in (which would make sense if the ACL entry was correct)
- severing the other two connections
- verified the default route from Router1 is exiting int s0/1/0
Not sure what might be causing it?
Ian001
Figured it out! I had:
access-list 1 permit 10.0.0.0 0.0.255.255
added to Router1's interface s0/1/0. Not sure why that affected telnet out however?
Oh right - because the telnet packets need to come back to Router1. Well this has been a learning experience
