Why does my 2621 reset to default configuration?
lminer314
Configured my 2621 router and today for no apparent reason it was reset to the default config. The configuration I set up is still there but not the configuration that initializes when the router boots.....it worked until this morning and now it's configured wrong....thanks
9 Replies 9
Prashanth Krishnappa
Check to see if you config register is set to ignore start up config(0x2142). Change it to 0x2102 and test.
nethelper
Level 3
Level 3
check if your configuration register is set to 0x2102 (as seen in the output below) and that you have saved your running configuration to the startup configuration (copy running-config startup-config):
2621> show version
IOS (tm) C2600 Software (C2600-JS-M), Version 12.2(3.5)T, MAINTENANCE INTERIM S
OFTWARE
TAC Support: http://www.cisco.com/tac
Copyright (c) 1986-2001 by cisco Systems, Inc.
Compiled Fri 03-Aug-01 22:45 by ccai
Image text-base: 0x80008088, data-base: 0x81631DD8
ROM: System Bootstrap, Version 12.1(3r)T2, RELEASE SOFTWARE (fc1)
2621_B uptime is 1 week, 4 days, 3 hours, 15 minutes
System image file is "flash:c2600-js-mz.122-3.5.T"
cisco 2621 (MPC860) processor (revision 0x200) with 56320K/9216K bytes of memory
Processor board ID JAD051516TX (503811939)
M860 processor: part number 0, mask 49
Bridging software.
X.25 software, Version 3.0.0.
SuperLAT software (copyright 1990 by Meridian Technology Corp).
TN3270 Emulation software.
Primary Rate ISDN software, Version 1.1.
2 FastEthernet/IEEE 802.3 interface(s)
24 Serial network interface(s)
2 Channelized T1/PRI port(s)
32K bytes of non-volatile configuration memory.
16384K bytes of processor board System flash (Read/Write)
Nethelper
Nethelper....thanks for the reponse....what I should have mentioned.....it did this overnight, while it was up and running....don't know how that is possible...unless it was hacked and reset to default....but I did have 0x2102 registered last night when I went home....this morning it was reset to default.....is there another reason you know why it would do this....thanks again.
how old is the device ? The only thing I can think of is some sort of an NVRAM or flash failure.
Can you post the output of ´show stacks´ ? That output can give indications on what is going wrong.
Nethelper
That is what I first thought.....but it would have to be a memory leak.....because the power was never off to the router....here is what you asked for...thanks
HLC2126>show stacks
Minimum process stacks:
Free/Size Name
11548/12000 Router Init
9824/12000 Init
5344/6000 RADIUS INITCONFIG
10276/12000 Exec
8620/9000 DHCP Client
Interrupt level stacks:
Level Called Unused/Size Name
1 908 8824/9000 Network interfaces
2 0 9000/9000 Timebase Reference Interrupt
3 0 9000/9000 PA Management Int Handler
6 450 8904/9000 16552 Con/Aux Interrupt
7 1134377 8920/9000 MPC860 TIMER INTERRUPT
can you post the output of 'show version' as well ?
Nethelper
Here's the version.....
HLC2126>show version
IOS (tm) C2600 Software (C2600-I-M), Version 12.1(26), RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2004 by cisco Systems, Inc.
Compiled Fri 15-Oct-04 16:13 by cmong
Image text-base: 0x80008088, data-base: 0x80833084
ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1)
HLC2126 uptime is 1 hour, 33 minutes
System image file is "flash:c2600-i-mz.121-26.bin"
cisco 2621 (MPC860) processor (revision 0x102) with 26624K/6144K bytes of memory
Processor board ID JAD043705CM (4083581012)
Bridging software.
8192K bytes of processor board System flash (Read/Write)
I run the output through the stack decoder, but that did not show anything...
I suggest the following: keep monitoring the router, if that same behaviour happens again, upgrade to a 12.2T version, your memory (32MB DRAM and 8MB Flash) supports e.g. 12.2(13)T16 (image name c2600-i-mz.122-13.T16.bin). 12.1, what you are running now, is rather buggy...
Nethelper
Ok...will do....thanks for your help.
