why every time after I save my codes in CLI tab in packet tracer, everything is gone?
When I open my file in CLI tab in Packet tracer of Cisco, I can't find my typing codes work there why?!
which commands are not working/missing ? Can you post the zipped Packet Tracer project (.pkt) file ?
System Bootstrap, Version 12.3(8r)T8, RELEASE SOFTWARE (fc1)
Cisco 1841 (revision 5.0) with 114688K/16384K bytes of memory.
Readonly ROMMON initialized
Self decompressing the image :
######################### [OK]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version
12.4(15)T1, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Wed 18-Jul-07 04:52 by pt_team
Image text-base: 0x60080608, data-base: 0x6270CD50
A summary of U.S. laws governing Cisco cryptographic products may be found
at:
export@cisco.com.
Processor board ID FTX0947Z18E
M860 processor: part number 0, mask 49
2 FastEthernet/IEEE 802.3 interface(s)
191K bytes of NVRAM.
63488K bytes of ATA CompactFlash (Read/Write)
Press RETURN to get started!
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0, changed
state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0.10, changed
state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0.20, changed
state to up
%LINEPROTO-5-UPDOWN: Line protocol on Interface FastEthernet0/0.30, changed
state to up
Router>sh run
% Invalid input detected at '^' marker.
Router>en
Router#conf t
Enter configuration commands, one per line. End with CNTL/Z.
Router(config)#
pls tell me where is my work that I already set up the router things in it?
where are command codes? pls help? I will have the vlan & tvp of packet
tracer this 14/5/2021.4d thursday in Hong Kong, the school name is
https://hkctsvt.edu.hk/tc.
pls read the following attachments that I already finished everything, that
are working for this review. But I can't find the command codes in
everything? why? of course I use save as to save everything when I finished
my work, thanks for your help?!
shirley
