Why is my STM-1/OC-3c to DS0 SPA showing out of service on asr 1002-x
kamel2020
Hello Cisco Community,
I need help troubleshooting an issue with my Cisco ASR 1002-X router. I recently installed the STM-1/OC-3c to DS0 SPA v2 module, and it's not functioning as expected. The module status is showing as "Out of Service."
Here are the details of my set.up:
1. Router Model: Cisco ASR 1002-X.
2. SPA Module: STM-1/OC-3c to DS0 SPA v2
 Is the STM-1/OC-3c to DS0 SPA v2 compatible with the ASR 1002-X?
What might be causing the "Out of Service" status?
Are there any additional configurations or prerequisites I might have missed?
Any insights or recommendations would be greatly appreciated!
Thank you in advance for your support!
8 Replies 8
@kamel2020
 What is the IOS version?
Cisco IOS XE Software, Version 03.10.00
Can you remove the SPA from the router and run the command " no upgrade fpd auto"
Insert the SPA again and  Check the SPA.
Or i need  STM-1/OC-3c to DS0 SPA version 1
Compatible
Show the output of the following command
show hw-module all fpd
Same issue
Btw i was wrôg about the version ios
Its Cisco IOS XE Software, Version 03.10.00
Can you please run the command " show hw-module all fpd"
and paste here the output?
