Why it cannot ping if the ping size is more than 300
wfqk
Level 5
Level 5
Hi Why it cannot ping if the size is more than 300. Please see the below. Thank you
Protocol [ip]:
Target IP address: 10.1.1.10
Repeat count [5]: 100
Datagram size [100]: 300
Timeout in seconds [2]:
Extended commands [n]:
Sweep range of sizes [n]:
Sending 100, 300-byte ICMP Echos to 10.1.1.10, timeout is 2 seconds:
Success rate is 11 percent (11/100), round-trip min/avg/max = 10/10/20 ms
We do not have enough information to answer your question. Please share your configuration.
HTH,
Meheretab
