why LSA 4 generated, need answer
Hello Team, I have quick query:Routing,
I have Sophos firewall along with 2 cisco router
Firewall192.168.15.1---------------192.168.15.2(CISCOR12)192.168.17.1---------------192.168.17.2(R4)
CISCOR12- network
192.168.15.0\24 in area 0 with process id 1
192.168.16.0/24 in area 0 with process id 1
192.168.17.0/24 in area 5 with process id 1
R4 router has 2 network
192.168.17.0/24 and loopback address -15.15.15.15 in area 5 along with process id 1
Sophos Firewall
192.168.15.0/24 and 192.168.10.0/24 in area 0
My question is why I am getting LSA 4 here. Please find attached the screenshot
CISCOR12
R4
3 Accepted Solutions
balaji.bandi
CISCOR12 as ABR: Your CISCOR12 router acts as an ABR because it has interfaces in both Area 0 (connecting to Sophos) and Area 5 (connecting to R4)
LSA Type 4 (ASBR Summary LSA) is a normal behavior triggered by the redistribution of external routes.
Routers in Area 5 (like R4) receive this Type 5 LSA, but they do not have a Type 1 (Router LSA) for the Sophos Firewall because Type 1 LSAs do not cross area boundaries.
check learning post :
https://learningnetwork.cisco.com/s/question/0D53i00000KsppkCAB/ospf-lsa-45
BB
ABRs are the Only Creators of Type 4 LSAs
A Type 4 LSA (ASBR Summary) exists for only one reason: to tell routers in other areas how to find the ASBR.
all routers (including the Sophos Firewall and CISCOR12) already have the Type 1 LSA (Router LSA)
You can verify on routers :
Show ip ospf database asbr-summary
Again, this theory is based on RFC; check Sophos Firewall documentation to match the same behaviour.
BB
Hello @babayagafebruary ,
the Sonic Firewall is only in area 0, the LSA type 4 is generated and fllooded in other areas area 5 in your case.
This is why the sonic firewall do not list an LSA type 4. It is not needed in area 0 because the ASBR node is directly connected to area 0 and routers in area 0 can check the E bit in the Router LSA of the ASBR node to check liveness.
The E bit in router LSA and the LSA type 4 in other areas allow each router to make an additional check before installing external routes i.e. LSA type 5.
if an LSA type 5 is present in OSPF DB but the originator ASBR is not also stating it is still an ASBR via E bit / LSA type 4 the LSA type 5 is ignored and not used.
Hope to help
Giuseppe
5 Replies 5
balaji.bandi
BB
Hello @balaji.bandi , just one more query, why in the Sophos Firewall I am not able to see LSA 4, this is expected that in Area0 only ABR has lsa4 . please find attached the screenshot of Sophos Firewall :
r12
BB
router id on the Sophos Firewall is 7.7.7.7
Hope to help
Giuseppe
