Wildcard mask question
milkdroogy
Hi i have this wildcard mask that i cannot understand:
0.0.31.254 i cant understand the 254 part, does this mean that it converts to 255.255.224.1 mask? i never seen a mask like that before.
it is taken from this ACL:
access-list 5 deny 172.26.192.0 0.0.31.254
Actually that's a valid WC mask. That's the beauty of WC masks they are so flexible that you could almost match anything.
.254 indicates it doesn't care about the first 7 bits in the last octet but the last bit (1 bit) has to match always. With an address 172.26.192.(0) the last bit is turned off therefore any address with the last bit turned off i.e any even # 0,2,4,6 etc.. will match this WC mask.
Sundar
Sundar
Pavel Bykov
Level 5
Level 5
You have to understand WC as not reversed subnet mask, but as bit sequence. If you convert the wild card to it's bit value.
Where there is 1, no match is required.
Where there is 0, a match is required.
